Page 18 - MetalForming May 2015
P. 18
coolant-cleaning technology with effective chip handling and removal. Its compact design will allow the conveyor to work alongside nearly any machine tool and coolant tank.
operating pressure: 1740 psi. Available in four lengths, the roller bars are in stock and ready to ship.
www.clrh.com
Fiber-Laser
Effortlessly Cuts
Touted as a reduced-maintenance alternative to a basic hinge-belt conveyor, the Clean- Sweep-RM allows chips and coolant to enter the load area of the conveyor where large chips are carried by the hinge belt and elevated to the discharge hopper. An internal chip-handling system removes small chips and fines while a removable screen box cleans the coolant. www.mayfran.com
Hydraulic Roller Bars Ease Die Changes
Cy Laser America, Sterling Heights, MI, introduces the CY2DL series of fiber-laser cutting machines—six models with work areas ranging from 4 by 8 to 10 by 40 ft.
These hydraulic roller bars from Hilma, Fenton, MO, can be used in pairs or in sets to lift dies as well as provide a roller surface to easily roll dies in and out of a press dur-
ing changeovers. For use in standard 11⁄16-in. or ASA T-slots, the bars’ hydraulically oper- ated supporting rollers allow easy inline movement.
The first machine in the series can be seen in operation at the new Cy Laser Demonstration Center in Sterling Heights, and features a work area measuring 5 by 10 ft. The new model CY2DL3015 is avail- able as a 2- to 6-kW machine and can cut anything from sheetmetal to 1-in.-thick steel plate, as well as 3⁄4-in. aluminum and stainless steel.
www.cy-laser.us
INNOVATION
G
N
I
H
T
Y
R
1
E
V
E
16
MetalForming/May 2015
Rollers can be positioned for front-to-back or left-to-right movement. Maximum
Always looking for a better way, COE has designed and launched a new HD-Series Straightener designed to handle AHSS.
SERVICE
SOLUTIONS
KNOWHOW
TRAINING
QUALITY
Don’t settle for less than
EVERYTHING
Coil processing equipment is what we build, but what we deliver is much more. Quality solutions backed by comprehensive service and training. Innovative engineering and skilled craftsmanship with dedication to detail.
COE Press Equipment delivers everything you need to improve your coil feeding operations.
Learn more at...
www.COEpress.com/everything
COE Press Equipment
+1 (586) 979-4400 | info@COEpress.com | www.COEpress.com
1-in. Steel Plate
