Page 49 - MetalForming May 2015
P. 49
VISI V21.1 also includes motion-study simulation tools, allowing the user to define timelines that control movement for various groups of components. With these tools, physical interaction of model geometry can be detected and the results of complex mechanisms simulated and investigated.
consistency within all milling operations, all of which dramati- cally simplify toolpath genera- tion, according to Vero Software officials. Feature- tree grouping, management of multiple setups/ features, and drag-and-drop capabilities with- in the tree ease navigation. All
2D toolpath is one highlight, where a simple milling operation now bases all remachining on the previous opera- tion. This means that all the correct areas are machined, even on flat areas of the toolpath, according to Vero Soft- ware officials. Full collision checks on all lead-in and retract movements ensure that 2D toolpaths are efficient.
The graphical user interface for 3D milling operations now shares a for- mat similar to that of the 2D CAM tool- paths in the new version. For exam- ple, the clearance area and oversize settings in the 3D operations will be in the same location as those in 2D oper- ations. In addition, the overall quality of surface finish is a major focus in the new software, with significantly improved point distribution and enhanced accuracy. To complement 2D and 3D toolpath developments, the G-code simulator provides users with an accurate virtual representation of the part before committing it to the machine. The quality and accuracy of
locked. Any change to a released model will create a copy of the data and update the revision number, provid- ing a history track and ensuring that part manufacture remains up-to-date.
The VISI 21.1 release also focuses on machining, including a new look for the CAM Navigator and command consolidation, and new dialogue-box
features within the tree can be moved, edited and mirrored. With a new ded- icated Undo mechanism for CAM, user mistakes easily can be rectified.
Version 21.1 also introduces the next generation of CAM toolpaths for VISI machining. The 2D milling operations have been consolidated and include many new options. Remachining on a
Tebis: The Process.
Software Consulting
Implementation Support
Contributing to your competitive edge.
Tebis provides efficient and technological advantages through CAD/CAM solutions for die, mold and machine manufacturers world- wide. That efficiency is best expressed as a comprehensive service portfolio
for end-to-end process solutions to include areas such as production-related and business consulting, CAD/CAM software modules, technical process knowledge
and outstanding support services.
Tebis America Inc.
400 E. Big Beaver Rd. Troy, MI 48083
USA
Tel. +1/248/5240430 info-america@tebis.com www.tebis.com
MetalForming/May 2015 47
