Page 4 - MetalForming August 2015
P. 4
ENSIS 3015 AJ
High-Precision Fiber Laser Processing of Thin-to-Thick Materials Without Additional Machine Setup
The ENSIS 3015 AJ is a revolutionary advancement in fiber laser cutting technology. This high-speed fiber laser cutting system has the ability to cut thin materials up to 4 times faster than a CO2 laser. In addition, an innovative resonator enables the ENSIS AJ to deliver both speed and power — utilizing 2 kilowatts to process up to 1-inch thick mild steel.
Developed by Amada, ENSIS technology changes the laser beam mode to efficiently process thin-to-thick materials without additional machine setup. Adjustments occur automatically based on the cut condition selected on the machine’s AMNC 3i control.
• 1.4g acceleration over the entire work area • Cutting speeds over 4,700 ipm
• Energy efficient
Machine:
ENSIS 3015 AJ (2kW)
MaterialType:
Mild Steel 1" Part Size: 5.5" x 3" ProcessingTime: 2 min.23 sec.
Key Processing Features:
• Amada’s Variable Beam Control Unit enables 4kW cutting capabilities in a 2kW machine
• Automatic nozzle changer eliminates setup between varying material types and thicknesses
HG 1003 Press Brake with Automatic Tool Changer
Triple or quadruple your number of bending setups per day. An Automatic Tool Changer (ATC) performs tool changes quickly and precisely — eliminating costly delays associ- ated with manual tool changes. The ATC is equipped with 18 magazines for dies and 15 for punches — providing the flexibility to accommodate rush jobs seamlessly. Now, complex tool layouts can be precisely loaded in three minutes or less.
