Page 13 - MetalForming September 2015
P. 13
News Fronts
apprentices at Oberg Indus- tries upon graduation. Approxi- mately 15 students will be participating in the JAA Pro- gram during the 2015-2016 school year.
Group (NASG) facility in Port- land, TN. The facility produces stamped parts and welded assemblies for automotive and other industries. This line joins 10 other Coe lines already installed at various NASG locations.
Fast and Flexible
BY AP&T
Increase your profitability with the right automation solution.
Oberg is a contract manu- facturer of precision metal components, tooling and stamping assemblies and a strategic contract manufactur- ing partner for companies in the aerospace, automotive and other markets.
The 72-in. line can process coil from 0.040 to 0.325 in. thick depending upon the width and steel strength. It features a 72-in. servo roll feed with a ServoMaster touch controller, a 72 in. by 14-ft. dual-threading table with a roller top, and a 50,000-lb.- capacity coil reel. The line also includes a Coe 406 powered straightener featuring ultra- sonic variable-speed loop con- trol with a three-position selector switch. Additionally, the system comes with perimeter guarding and safety controls. Coe also provided
Facilities
North American Stamping Group Installs Coil-Processing Line
Coe Press Equipment, Ster- ling Heights, MI, announced that it has recently installed a new press-feeding line at the North American Stamping
APTGROUP.COM
YOU CAN GET THE BEST VALUE, PERFORMANCE, DELIVERY AND SERVICE...ALL FROM HEIM!
TM
With Maxi-Stamper® presses on your floor, you also realize these benefits...
HEIM delivers what we promise...a solid machine that performs to your requirements, backed by support that’s second to none.
HEIM can engineer a single-point, two-point, four-point or customized Maxi-Stamper® press to meet your needs...whether you need a single press or a complete turnkey system.
...all made in America with our family pride, standing right behind every machine.
SEE HEIM IN ACTION
LET THE HEIM TEAM HELP 1-800-927-9393 www.theheimgroup.com Chicago, Illinois MetalForming/September 2015 11
Our Maxi-Stamper® presses represent the leading edge in design and engineering for applications in the 90 to 1000 ton range.
H
