Page 62 - MetalForming October 2015
P. 62
Previews
Corrosion-Inhibiting
Packaging for Steel Coils
and Metal Parts
Daubert Cromwell
deck sheets of Premium Metal-Guard VCI film on top to protect exposed, unfinished metal edges. The VCI pallet liner paper acts as a barrier between the metal and the acidic wood, and keeps moisture away from the exposed underside of the unfinished coil edges. On top, a 3-mil clear VCI deck sheet covers the coil edges and prevents corrosion-causing contaminants from affecting exposed surfaces.
to keep them packed tight and secure on the pallet, ready for easy transport. Rolls then are safely shipped to a finisher for additional processing. When the VCI pack- aging is removed, the metal is immediately ready to use. Surfaces are clean, dry and can be used without further handling or rework. www.daubertcromwell.com
Magnetic Drilling Machine
CS Unitec Booth N26010
Booth S4305
Daubert Cromwell, Alsip, IL, provides cor- rosion-inhibitor packaging to protect steel coils and other metal parts in all stages of production, storage and shipment.
Ferro-Pak VCI sheets are used to sep- arate finished coil from wooden pallets, with
Coils are wrapped in a plain stretch film
60 MetalForming/October 2015
CS Unitec, Norwalk,
CT, displays its new
magnetic drilling
machine, the MAB
1300, designed for con-
tinuous use in heavy-
duty drilling applica-
tions. The drill’s
20-A/110-V double-insu-
lated, reversible motor is
ideal for drilling struc-
tural steel and other
metals. The versatility
of the four-speed oil-
bath gearbox allows
drilling of holes from 7⁄16- to 51⁄8-in. dia. with annular cutters. The MAB 1300 has a 11⁄4-in. arbor with an adapter for 3⁄4 in. The unit includes an integrated automatic cooling/lubrication system to increase the life of the annular cutters by reducing friction and wear. www.csunitec.com
Rapid-Prep Belts
with Increased Life
Saint-Gobain Abrasives Booth N24064
Saint-Gobain Abrasives, Worcester, MA, debuts Norton Vortex rapid-prepara- tion belts and other new products. The pro- prietary agglomerate grain of Vortex rapid- prep reportedly increases belt life as much as three times that of aluminum- oxide grain and reduces two to five grit sequences in blending operations, sub- stantially reducing labor and material costs. In addition, these belts incorporate proprietary Clean Bond resin technology for smooth, smear-free finishes, eliminating rework process steps and improving pro- ductivity. www.saint-gobain.com
