Page 68 - MetalForming October 2015
P. 68
Retrofitness
New Punching and Shearing Cell with Linear Drives
Previews
Prima Power North America, Inc. Booth S931
The new Shear Brilliance punching and shearing cell from Prima Power North Amer- ica, Inc., Arlington Heights, IL, is constructed with the lat- est composite materials, servo-electric technology and linear drives to enable improved productivity in flex- ible fabrication.
66
MetalForming/October 2015
The fully servo-electric
Shear Brilliance features linear-drive technology for rapid sheet positioning. With long travel of the 4070-mm coordinate table, the full 3100-mm working area for punching and shearing can be used without repositioning. Sheets are pre-positioned during machine operation, which reduces loading time.
Get your machinery in shape with Delta Motion Controllers. And use our versatile RMCTools software to strengthen productivity, quality and uptime.
Get fit. Retrofit. Just call 1-360-254-8688 or visit deltamotion.com
RMC75 and RMC150 Motion Controllers
1-2 Axis Multi-axis
The cell’s 1300-hits/min. punching speed adds productivity, and large tooling capacity in a 24- or 30-station turret ensures minimum setup times and maximum tool quantity in single setup. Tool sizes can be chosen by the user, which adds flexibility in production.
As much as 35 tons of servo-electric ram force—the highest available in servo-elec- tric punching, according to company officials—allows for complex contours, using one hit instead of two. As fewer hits are needed, production speed is improved. Also, auto- matic clearance setting of the intelligent servo-electric right angle makes changing from one material thickness to another automatic and rapid.
The Shear Brilliance allows for shearing of a wide range of material thicknesses, to 5 mm for aluminum, 5 mm for mild steel and 3 mm for stainless steel. Maximum sheet size for punching and shearing is 3100 by 1565 mm.
Automatic loading, part exit and scrap removal come standard with the cell.
Forming and Diemaking Software
AutoForm Booth S4337
Guide Units in Inch Measurements
AutoForm, Troy, MI, offers design and optimization software for the diemaking and sheetmetal-forming industries. The software, boasting accurate results and short com- putation times in an intuitive user interface, can improve reliability in planning, reduce die-tryout time, and result in higher-quality part and tool designs. More than 600 com- panies across 40 countries employ AutoForm software to minimize development time and costs. www.autoform.com
Steinel Normalien Ag Booth S4120
Steinel Normalien Ag, St. Charles, MO, specializes in punching and bending technology and showcases guide units in inch measurements.
The company has long provided standard guide units for tool shops, but also devel- ops and produces customized guides. Live presentations demonstrate the use of these components. Steinel shares its FABTECH booth with Champion Tools, the commercial agency for Steinel in the United States. www.champion-dietool.com
www.primapower.com
