Page 92 - MetalForming October 2015
P. 92
Previews
Deburring and Edge-Rounding Machines,
and Coil-Line Control Software
ring and rounding, with throughput rates of more than 300 sq. m/hr. The company also demonstrates rapid, simple parts leveling on the FlatMaster 55, a machine that enables novice users to pro- duce dead-flat, virtually stress-free metal parts on the first try by entering as few as two values into the control: material type and thickness. The servo-hydraulic FlatMaster can leveling and stress-
Arku Coil Systems, Inc. Booth S508
Arku Coil Systems, Cincinnati, OH, demonstrates the EdgeBreaker line of programmable deburring machines; introduces Edge-Racer pro-
relieve metal parts from 0.5 to 60 mm thick, to 3000 mm wide. New Arvis 4.0 coil-line-control software brings coil processors higher uptime and productivity with an operator interface designed for the “mobile” generation, giving operators a cockpit display of the condition and performance of a coil line’s interconnected mod- ules. www.arku.com
grammable edge-rounding machines, demonstrates part-leveling technology;. and debuts Arvis 4.0 coil-line-control software.
Quick-Change Transfer Rails
EdgeBreaker machines can remove thick slag and heavy burrs to 3 mm on metal parts to 80 mm thick and 1300 mm wide. The EdgeBreaker’s oscillating roller self-cleans residue from the grinding belt, while sanding blocks gently round the edges on both sides. The belt is designed to provide high abrasion and allow rapid changes.
ATI Industrial Automation Booth N24010
EdgeRacer models are designed for use on thinner parts, to 50 mm thick. Made by German brush-technology company Wöhler and sold by Arku, the EdgeRacer can remove oxide layers and han- dle 3D parts or those with polished, brushed or coated surfaces. Two machine styles provide single-sided or double-sided debur-
ATI Industrial Automa-
tion displays its rail tool
changers, which allow for
quick changeover of press
transfer rails. The tool
changers are engineered
to withstand the high speed
and inertia loading environment typical with this process.
www.ati-ia.com
Smooth Texture Powder Coating
HIDES FABRICATION MARKS
OTHER POWDERS AVAILABLE
Specialty Spring Steel?
The Service Center that never closes.
www.admiralsteel.com
See Our Entire Catalog Online For Full Product/Tech. Information.
HR/CR As Rolled–Annealed–Tempered 1020-1035-1050-1075-1095-5160-4130-6150 Sheet, Plate, Coil, Bar, Strip
TM
ISO 9001 REGISTERED
4152 West 123rd Street • Alsip, Illinois 60803-1869
800-323-7055 • Fax: 708-388-9317
e-mail: sales@admiralsteel.com
Admiral is a registered trademark of Admiral Steel LLC. Alsip, Illinois. Reg. No. 2430959. All rights reserved.
90 MetalForming/October 2015
Visit Us On The Web!
