Page 45 - MetalForming December 2015
P. 45
Classifieds
EQUIPMENT FOR SALE
STAMPING PLANT LIQUIDATION Assets of Tier 1 Automotive Supplier
Located in Kitchner, Ontario, Canada
Inspect In Plant Under Power
120 Ton Aida Gap
(3) 165 Ton Aida Gaps
250 Ton Warco w/ Feed Line
(3) 275 Ton Aida
(3) 300 Ton Minsters w/ Feed Lines (3) 300 Ton Minsters w/ Feed Lines 350 Ton Warco w/ Feed Line
(2) 400 Ton Minster w/ Feed Line
UNIVERSAL PRESS & MACHINERY, INC. 44235 N. Groesbeck Hwy, Clinton Twp., Michigan 48036
(586)569-0150 www.universalpress.com • sales@universalpress.com
PRESSES COMPLETE FEED LINES LINEAR TRANSFER TUBE MILL SLITTING LINE ROBOTIC WELDING CELLS WIRE STRAIGHTENERS Minster / Aida / Bliss Wean United / Loopco Sesco / Colt / Linear
Minster
Aida w/ Feed Line
CMC Bliss
Wilkens & Mitchell w/ Feed Line Bliss w/ Feed Line
Wean United w/ Feed Line
Bliss w/ Feed Line
400 Ton
400 Ton
400 Ton
400 Ton
600 Ton
600 Ton
800 Ton
1500 Ton CMC Bliss w/ Feed Line 16 Stand Contour 3.5” Tube Mill 60” Loopco Slitting Line
American Machine Tools Corp.
www.AmericanMachineTools.com
“Can I get 500 copies
Have you been wanting extra copies of an article published in MetalForming for your own promotional efforts— trade shows, meetings, mailings, etc?
of that article?”
Reprints are cost effective and will produce a high-quality piece of litera- ture for your particular needs.
We do all the work, and you’ll have your reprints in three weeks—all at a surprisingly low cost!
Call Sue Cubranich at 216-901-8800 scubranich@pma.org for full details.
EQUIPMENT “FOR SALE BY OWNER!”
• 800 Ton Warco Press 132" x 60", Stroke 26" • Adj 18" • 20 SPM
• 28-Stand Tishken 3" Duplex Rollformer • Roll space adj 30-40"
• 120,000 lb Pneum. Die Cart 24"x96"x144" • train track wheel design • Exclusive broker for 5000 Ton Bliss Hydraulic Press 204" x 84"
Stroke 48" • Shut Ht. 84" • Daylight 132" • (4) post Contact Edward Voss • edvoss@metalformservices.com Ph# (586) 933-3815 • www.metalformservices.com
IN PLANT UNDER POWER for Immediate sale from large midwest stamping company
• 1000 Ton Bliss straight side single crank press, SE1-1000-48-48, 20" str, 7" adj, 23.8" SH, 48" x 48" BA, cushions, 1967, all updates
• 800 ton Minster straight side double crank press Model E2-800-60-48, 18" str, 6" adj, 48" x 60" BA, cushion, 15-30 spm, windows, floor standing
• 400 ton Clearing straight side single crank, F1-400-42, 20" str, 4" adj, 17" SH, 32" x 42" BA, cushion
• 1/2" x 32" wide x 72" O.D. Macintosh coil cradle /straightener feed
• 32-60" Blanchard rotary surface grinder, 75 h.p., 1966, soft start, like new chuck life, coolant, 16" vert, good running condition
20501 Hoover Road • Detroit, MI 48205
T: +1 313-499-6490 • F: +1 313-499-6494 E: chip@pfisales.com • AMGroupOnline.com
MetalForming/December 2015 43
