Page 14 - MetalForming February 2016
P. 14
Safety Update
Fume Extractor for Variety of Welding Applications
The PR weld-fume extractor from Movex Inc., Northhampton, PA, provides high positional stability, capture efficiency and maneuverability, enabling
it to fit virtually any welding application. It maintains low pres-
sure loss due to its external support design, which also
allows for simple cleaning and tension adjustment
without disas-
sembly. The PR
is available in diameters of 4,
5, 6 and 8 in. and in lengths from 5 to 36 ft. The
PR’s range enables it to cover the required working area while providing
a constant cfm exhaust volume. The arm can be equipped with LED light-
ing and switches to control the fan and damper. An ATEX version in
all configurations also is available when the PR is slated for use in areas
of explosion risk due to electric discharge. Optional brackets for floor or ceil-
ing mounting can be ordered to accommodate nearly any workspace.
Movex Inc.: www.movexinc.com
Four-Sided Safety Enclosure for Machinery
of-operation high-speed door and cage fencing. It provides protection for manu- facturing processes ranging from robotics to simple stretchwrap applications on the dock. The cell consists of the RoboGuard modular fencing system of posts, panels and doors along with the Defender auto- mated barrier door.
Rite Hite Machine Guarding: www.ritehite.com
The Defender Cell, from Rite Hite Machine Guarding, Milwaukee, WI, is a four-sided safety enclosure for any type of machinery, and includes a Category 4 interlocked point-
When welders can’t make out all of the details of a weldment, or distinguish col- ors through the auto-darkening filter of a welding shield, it can make welding more challenging. To give welders superior vis- ibility in dark and light states, 3M, St.
Auto-Darkening Filter Gives Welders Optimum Visibility
“ We had seconds to connect air, fluid and power to an assembly platform. Hello ATI.”
The fully automated ATI Utility Coupler delivers what no manual solution can. Speed and reliability. Unique among all other automated solutions, ATI’s built-in engineered rotational compliance ensures reliable coupling. And our common mounting flats are compatible with ATI’s vast selection of tool changer utility modules. ATI is also compatible with DeviceNet, Ethernet and Profinet. So, if you’re ready to add a new level of speed and reliability to your manufacturing process just say, “Hello ATI.” See it now at www.ati-ia.com/utilitycoupler.
12 MetalForming/February 2016
