Page 30 - MetalForming February 2016
P. 30
FABTECH 2015—It’s a Wrap
Magnetic Drill Offers Powerful, Controlled Hold on Curved or Flat Work
Magswitch Technology, Inc., Lafayette, CO, launched several new products at FABTECH. Included was the MagDrill Disruptor 30, fea- turing the company’s shal- low-field magnetic technol- ogy. The first of a series, the MagDrill uses patent-pend- ing pipe conformability, with its flexible drill base reportedly providing supe- rior grip on flat and round surfaces via a pivoting mag- net-base design. The light-
weight tool requires no electricity and provides a controlled, powerful hold on range of steels—flat or curved.
The progressive actuation of the magnetic force provides pre- cise positioning before applying the full-magnet hold. Impor- tantly, according to company officials, the magnet turns com- pletely off and does not accumulate magnetic material from the drill site. For increased safety, the locking feature of the base pre- vents magnet arrays from deactivating during use, thus ensur-
Breakthrough Capacitor-Discharge Resistance-Welding Technology
Dengensha America demonstrated its new Flexwave resistance-weld machine, with flexible waveform technolo- gy, at FABTECH. The machine combines the capabilities of a
capacitive-discharge welder (CDW) and a 15,000-Hz bipolar medium-frequency con- verter (MFC) to offer enhanced control of energy release. We saw firsthand how the technology controls heat input and optimizes weld-nugget quality on steel and aluminum, as well as dis- similar materi- als, with weld parameters that are simple to set. And, the technology maximizes waveform flexi- bility, allowing fine-tuning of tempering, demagnetization,
upslope, etc.
The new Flexwave Welder Series includes the NICP-050,
NICP-100, and NICP-150 models, with maximum weld cur- rents of 50,000, 100,000 and 150,000 A respectively.
ing safer tool operation.
www.magswitch.com.au
www.dengensha.com
Some Metals Shouldn't Move.
Bunting. Because Other Metals Need To.
Keep your metals - and business - moving with Bunting® Magnetics. Our strong, high-energy magnets, quality manufacturing and innovative designs tower over the rest, taking your metal precisely where it
needs to go, quickly, easily and efficiently. MagLiftTM Hand Controlled
Magnetic Lifters
Lifts hundreds to thousands of pounds of metal safely. (275 lbs - 4400 lbs)
Ask about our 10-DAY Trial Offer.
(Offer only available in the U.S.A. and Canada)
To order a MagLiftTM call or click: 800-232-4359
buymagnets.com
MagSlide® Conveyors
Built to move any scrap metal - dirty, oily, jagged, or abrasive. Bunting's ruggedly constructed, beltless conveyors can handle the jobs that conventional conveyors can't.
The Leader In Moving, Removing & Holding Metal For Over 50 Years
To see our complete line, call or click
(800) 835-2526
buntingmagnetics.com ©2016 Bunting Magnetics Co.
MetalMizer MV2018 The Affordable &
Versatile Vertical Bandsaw that Stands Out
• Convenient overhead controls
• 45° tilting saw head
• 18"x20"cutting capacity • Made in the U.S.A.
Limited Quantity!
Available for Immediate Shipment
800.522.5097 metalmizer.com
Also depend on the METALFLEX blade to meet
your high-quality metal sawing needs.
28 MetalForming/February 2016
© 2016 MetalMizer
