Page 8 - MetalForming April 2016
P. 8
News Fronts
Business Notes
Falcon Steel Launches Material-Management Program
we be able to serve our cus- tomers better, it will make us more cost-efficient and allow us to direct resources toward even more innovations for our customers.”
The program allows cus- tomers to plan and order in advance for steel structures to be fabricated within a given forecast. Fabricated structures
“Our customers,” Taylor continues, “not only gain more control during the delivery process itself, they also can improve profitability and reduce costs throughout the entire supply chain.”
“This software program was inaugurated out of the sheer amount of RFQs that we process day-after-day,” says David Berdass, Bermo vice president. “Not only will
Alliance Steel LLC, Bed- ford Park, IL, has acquired the working capital assets and customer list of Stan- dard Steel & Wire Inc., Chica- go. With the acquisition, the steel service center has formed the Specialty Steel Division of Alliance Steel,
then are stored onsite within designated secure inventory- management areas and man- aged by Falcon until the cus- tomer schedules delivery.
Bermo Releases
New Quoting Software for Customers
Falcon Steel, Fort Worth, TX, has debuted a material- management program designed to give customers greater flexibility and shorter lead times between order and delivery. A producer of steel structures for power-delivery systems, Falcon Steel report- edly is the only manufacturer and fabricator of extra-high- voltage lattice towers, steel poles and substation struc- tures based in the United States.
According to Jim Taylor, CEO of Falcon Steel, the pro- gram makes it possible to deliver products within 3 to 4 weeks of a request, far shorter than the industry’s typical 16 to 20 weeks.
Bermo Inc., Minneapolis, MN, has released its F.R.E.D. (First-of-its-kind Rapid Esti- mate Delivery) quotation soft- ware, created inhouse to pro- vide automated quotations for its OEM customer base. The program links customers’ CAD models to suit Bermo’s manu- facturing processes, which include laser cutting, metal stamping, forming, welding and assembly. With the new software, customers can expect to receive quotations within minutes.
This spring, updates to the F.R.E.D. software (the name also is a nod to the company’s late founder, Fred Berdass) will give customers the ability to perform online preliminary quotations before having to send in requests.
“By having the right prod- uct ready to go at the right time,” says Taylor, “our pro- gram gives utilities much more flexibility in their ability to forecast, order and replen- ish product inventory.
Alliance Steel Acquires Standard Steel & Wire
Precision Edge Rounding & Finishing
Deburring Deslagging Edge Rounding Laser Oxide Removal Surface Finishing
WEBER PT
Perfect metal machining at its best
Booth #N6485
Up to 4 stations
43", 53" and 63" widths New generation Weber
"i-Touch" screen control
Variable grinding belt length
CBF technology for a perfect surface finish
Easy accessibility for maintenance
Modular design for flexible station arrangement Optional top/bottom machining
MRB brush system for perfect edge deburring
Hans Weber Sales & Service
P 913.254.1611 • F 913.254.1582 sales@weberamerica.com • www.weberamerica.com
6 MetalForming/April 2016
