Page 25 - MetalForming May 2016
P. 25
Press Controls For All Presses
One Source
One Solution
Toledo Integrated Systems
Press Pilot 150 Control
We Provide Solutions For...
Mechanical Presses Hydraulic Presses Forging Presses Transfer Presses
Maximizer TPC (Total Press Control)
Toledo Integrated Systems Toledo Transducers, Inc.
www.ToledoIntegratedSystems.com 800-T-Toledo 419-867-4170
steel on our plasma-cutting machine and then drill any of the holes that were required. The secondary hole- drilling process diminished through- put, not to mention the need to sand off any edge discoloration from plasma cutting. That’s all become a thing of the past with the new waterjet machine.”
We saw several examples of the quality of the work coming off the new waterjet machine. Included were parts being cut from Type 304 stainless-steel sheets (5 by 10 ft.) for fabricating chutes and ductwork for a General Mills food- processing plant; and copper inserts for furnace nozzles, fabricated for a com- pany that gas-atomizes metal powder.
“When we were automotive- focused,” says Wolfe, “it often was dif- ficult to differentiate ourselves from the several other shops around that can do that kind of work. Now, thanks in part to becoming experts in stain- less-steel fabrication, we can make a name for ourselves and separate from the pack.” MF
Made to Handle Metal.
We help you make
things faster, safer... better.
Industrial Magnetics, Inc. fabricates innovative and unique magnetic solutions for industrial lifting, holding, fixturing and moving applications as well as a wide variety of conveying products for ferrous metal parts, lids, containers and more.
Plates, Pipes, Parts... No Problems!
888.582.0823 • www.magnetics.com
MetalForming/May 2016 23
