Page 33 - MetalForming May 2016
P. 33
Industry Leading Storage for Sheet Metal Fabrication Tooling
Moving Your Lean Manufacturing Program Forward
Compliments “Lean” and “5S” Initiatives
Cabinets and Carts available for all styles of Press Brake and Turret Tooling
A Big Boost to Production Capacity
Icon stamps an array of small- to medium-sized stampings, delivered to its inhouse resistance-welding cells as well as to its sister engine-cradle assem- bly plant in Riverside, MO. Among its high-volume jobs are structural apron parts, cross members and other body- in-white parts.
All of the company’s efforts in the laLst couple of years to drive productiv-
ity have added up to allowing Icon to a doubling of throughput from Icon’s pressroom, with only a nominal increase in head count and without adding new presses. For example, the 2000-ton Komatsu transfer line now runs at 17 to 20 strokes/min., up from 12 to 14 strokes/min. prior to the upgrades.
The press, with a 108 by 216-in. bed, stamps 16 different production parts, and several service parts. Of these, 75
Icon Metal Forming stamps an array of small- to medium-sized automotive body-in-white stampings, delivered to its inhouse resistance-welding cells as well as to its sister engine-cradle assembly plant in Riverside, MO.
percent utilize the inline shear and blank-handling setup (in progressive mode, the shear stays open and the coil feeds through directly into the press). And, the press’s original transfer
system also received a refresh in 2015, with state-of-the-art Rockwell servo drives added on all three transfer axes to further increase press versatility.
“Twenty percent of the new jobs coming in consume advanced high- strength steels,” says assistant materi- als manager Kevin Harbeson. “And we expect that amount to double within the next couple of years as we begin to take on more and more undercarriage work.” MF
WORK SAFER. INCREASE EFFICIENCY. PROTECT TOOLS.
For MetalForming Special Offer Go to this link
66.382.0482
www.metalformingmagazine.com MetalForming/May 2016 31
