Page 53 - MetalForming May 2016
P. 53
sides of the coil at the beginning of the die. These notches also can serve as pitch-control notches to prevent overfeeding.
THE BIG NAMES TRUST US. THE SMALL ONES TOO.
Our clients know they can always expect custom solutions from us, whether they are big or small. A highly qualified team is always ready to provide effective answers to any need because we control the entire production process. Sensors for force, position, pressure and temperature measurement; indicators, power and temperature controllers; automation platforms and industrial inverters: whatever your need, you can trust us.
GEFRAN INC
8 Lowell Avenue Winchester, MA 01890 - Toll free 1-888-888-4474
info.us@gefran.com - www.gefran.com
The MiniCoater line of roller coaters places lubricant on coil stock before it enters the die. Computer control allows the MiniCoater to dispense the correct amount of lubricant on each cycle of the press. Individual manifolds can be
provides
A less-obvious cause of carrier-web stretching is roll pressure in the feed sys- tem. In general, the pressure on the feeder rolls should be set as high as possible without causing damage to the material. High roll pressure allows the feeder to accelerate aggressively without the material slipping. However, excessive feed-roll pressure can induce edge wave in the material.
When a die closes on material with edge wave—especially thin materials—the pressure provided by the stripper plate will flatten these waves, causing the car- riers to increase in length during the die operations. When the die opens, the waves return to their original shape and the carrier will become shorter again. This con- dition can create all kinds of in-process variation that can be very difficult to iden-
tify, especially if one is not looking for it.
MF
Tooling by Design
Roller
Resistance Welding Machinery • Standard & Special Design • New & Used • Parts & Supplies 24/7 Service • ProcessTraining • Repairs • Control Upgrades •Water Chillers
DIVERSE CONSUMABLES INVENTORY STANDARD & SPECIAL DESIGN RESISTANCE WELDERS
Helping customers succeed with resistance welding for 50 years www.tjsnow.com | 1-800-NOW-SNOW | welders@tjsnow.com
MetalForming/May 2016 51
Rugged
Learn the full MiniCoater story at ...
Rockford, IL
p: 815-226-8090
f: 815-226-9250
e: sales@lspind.com
