Page 57 - MetalForming May 2016
P. 57
$510,000 proposed penalties related to these seven previously uncited spinning machines. Backing up, OSHA had cited the 1910.212 operator-ingress-protection standard not for oper- ator-access exposure but only for not guarding against the ejection of workpieces. In an appeal of Judge Welsch’s dis- missal decision, it was admitted that OSHA had never before issued a citation such as the one issued to Loren Cook.
OSHA basically argued that it could change and interpret any OSHA standard through an unprecedented citation because a U.S. Supreme Court case, CF&I Steel/Martin v. Occupational Safety and Health Review Commission (the 1991 “Martin” case), 499 U.S. 144, allowed it to re-interpret “rotating parts” of machinery, stretching the term to mean fly- ing ejected workpieces.
Judge Welsch determined in Loren Cook that:
• “The hazards...share the nature and quality of being cre- ated by the routine operation of the machine.
• “Point of operation, ingoing nip points, rotating parts, and flying chips and sparks” are the normal, expected result when running the machine.
• An ejected workpiece is not of the same nature and quality of the listed hazards. It is the result of a machine mal- function. The “flying sparks and chips” listed in the standard are qualitatively different from the 12-lb., almost 3-ft.-dia.
workpiece that the lathe ejected on May 13, 2009. Chips and sparks are the by-product of a routine process—they are not the product itself.
As the judge related, Section 1910.212(a)(1) lists point of operation, ingoing nip points, rotating parts, and flying chips and sparks as hazards that must be guarded against. OSHA did not allege any of these hazards in the alleged vio- lation descriptions (AVDs). Instead, it was alleged that Loren Cook failed to protect its employees from “metal parts and debris being ejected from the machine.”
The judge also noted that a certified safety and health official (CSHO) testified that OSHA did not cite Loren Cook for a point-of-operation violation under § 1910.212(a)(1) (Tr. 717-718). The CSHO also acknowledged that OSHA did not cite the company for an ingoing nip-point violation in any of the seven AVDs. OSHA’s expert Dennis Cloutier tes- tified that the lathes at issue did not present a hazard with respect to points of operation, ingoing nip points or rotat- ing parts. And, there is no evidence in the record showing that the lathes created flying sparks or chips during their operation.
“The court determines, based on the clear language of § 1910.212(a)(1), that the cited standard does not apply to ejected workpieces cited in this proceeding. Accordingly,
Late steel delivery can cripple production and drag down profits. With on-time delivery Admiral keeps your operations running smoothly and efficiently. That’s one reason why fabricators and manufacturers have trusted Admiral for over 65 years. Whether you need 10 lbs. or 10,000, Admiral delivers what you need, when you need it, with first-class quality and personalized service. Contact us for a quote today!
TM
Admiralsteel.com ISO 9001 REGISTERED
4152 West 123rd Street Alsip, Illinois 60803-1869
Ph: 800-323-7055 Fax: 708-388-9317 email: sales@admiralsteel.com
Admiral is a registered trademark of Admiral Steel LLC. Alsip, Illinois. Reg. No. 2430959. All rights reserved.
You and The Law
Some Metals Shouldn't Move.
Bunting. Because Other Metals Need To.
Keep your metals - and business - moving with Bunting® Magnetics. Our strong, high-energy magnets, quality manufacturing and innovative designs tower over the rest, taking your metal precisely where it
needs to go, quickly, easily and efficiently. MagLiftTM Hand Controlled
Magnetic Lifters
Lifts hundreds to thousands of pounds of metal safely. (275 lbs - 4400 lbs)
Ask about our 10-DAY Trial Offer.
(Offer only available in the U.S.A. and Canada)
To order a MagLiftTM call or click: 800-232-4359
buymagnets.com
MagSlide® Conveyors
Built to move any scrap metal - dirty, oily, jagged, or abrasive. Bunting's ruggedly constructed, beltless conveyors can handle the jobs that conventional conveyors can't.
The Leader In Moving, Removing & Holding Metal For Over 50 Years
To see our complete line, call or click
(800) 835-2526
buntingmagnetics.com ©2016 Bunting Magnetics Co.
MetalForming/May 2016 55
