Page 12 - MetalForming June 2016
P. 12
Delivered: Large Liquor- Storage and Agitator Tank
Ci Metal Fabrication, Meridian, MS, recently was tasked with fabricating this large liquor-storage and agitator tank for an OEM contractor with a very intensive list of require- ments and specifications. Ci, which serves the power gen- eration, pulp and paper, chemical, and automotive industries,
operates out of a 57,000-sq.-ft. plant, where it rolls, forms, shears and welds sheet and plate to 1 in. thick.
To fabricate this tank—15 ft. wide by 30 ft. long by 15 ft. tall—the Ci shop started with 1⁄2-in.-thick plate of Type 2205 duplex stainless steel (21-23 Cr, 4.5-6.5 Ni, 2.5-3.5 Mo; 620-MPa tensile strength). Car- bon-steel supports were added to the exterior of the tank.
The tank was fabricated to API 650 specifications, which required extensive welding and nondestructive testing. Weld coupons were fabricated for bend-and-break testing. Before the tank could be shipped, the interior and exterior of the stainless-steel shell underwent a thorough decontamination cleaning process.
Ci Metal Fabrication: www.cimetalfab.com
YOU CAN GET THE BEST VALUE, PERFORMANCE, DELIVERY AND SERVICE...ALL FROM HEIM!
TM
With Maxi-Stamper® presses on your floor, you also realize these benefits...
HEIM delivers what we promise...a solid machine that performs to your requirements, backed by support that’s second to none.
HEIM can engineer a single-point, two-point, four-point or customized Maxi-Stamper® press to meet your needs...whether you need a single press or a complete turnkey system.
...all made in America with our family pride, standing right behind every machine.
SEE HEIM IN ACTION
LET THE HEIM TEAM HELP 1-800-927-9393 www.theheimgroup.com Chicago, Illinois www.metalformingmagazine.com
Our Maxi-Stamper® presses represent the leading edge in design and engineering for applications in the 90 to 1000 ton range.
10 MetalForming/June 2016
H
