Page 14 - MetalForming September 2016
P. 14
Materials & Coatings
Handheld Alloy-ID Analyzer Achieves MIL-STD-810G Certification for Rugged Metal Analysis
provided in less than 2 sec.
Rigaku Analytical Devices: www.rigakuanalytical.com
Rigaku Analytical Devices, Wilmington, MA, a manufacturer of handheld and portable spectroscopic ana- lyzers, announced that its handheld laser-induced breakdown spec- troscopy analyzer, the KT-100 Katana, has achieved MIL-STD- 810G and IP-54 certification. The KT-100 proves ideal for scrap- metal sorting and positive material identification in metal-fabrication plants, petrochemical plants and
YOU CAN GET THE BEST VALUE, PERFORMANCE, DELIVERY AND SERVICE...ALL FROM HEIM!
other sites requiring fast, accurate and robust methods for alloy identification.
To guarantee protection against dusty and harsh work environments, the device underwent strict testing to MIL-STD-810G. The tests involved rigorous vibration, shock and drop testing, which focused on impact to every angle of the instrument. Use it for on-the-spot metals classification, including aluminum grades, with results
“The Hydroflex system can use one or more carrier gases—nitrogen or argon— to maintain the furnace pressure while a controlled ratio of hydrogen helps prevent oxidation,” explains Linde’s Akin Malas. With the Hydroflex technology, many annealing tasks can be completed with
Advanced Atmosphere- Control System
for Annealing
Linde LLC, Bridgewater, NJ, has intro- duced its Hydroflex atmosphere-control system, a universal solution for clean and bright oxide-free annealing of steel, stainless steel, copper, bronze or brass. Applications include automotive, aerospace and military components, construction and industrial equipment, and electrical systems.
TM
With Maxi-Stamper® presses on your floor, you also realize these benefits...
HEIM delivers what we promise...a solid machine that performs to your requirements, backed by support that’s second to none.
HEIM can engineer a single-point, two-point, four-point or customized Maxi-Stamper® press to meet your needs...whether you need a single press or a complete turnkey system.
...all made in America with our family pride, standing right behind every machine.
SEE HEIM IN ACTION
Our Maxi-Stamper® presses represent the leading edge in design and engineering for applications in the 90 to 1000 ton range.
12 MetalForming/September 2016
Booth C15019
LET THE HEIM TEAM HELP 1-800-927-9393 www.theheimgroup.com Chicago, Illinois
H
