Page 25 - MetalForming October 2016
P. 25
Standard Features of Twister:
• Automatic Gas Change
• Auto setting of cutting parameters • Push-Pull “zoned” exhaust
• Full 2 year control warranty
• Laser Marker targets exact position • Automatic anti-spatter system
• Automatic Argon Marking system
www.komatsuplasma.com 978-658-1650
Booth C17070
IF THIS IS A TYPICAL WEEK AT YOUR SHOP... WE SHOULD TALK.
When you’re 5-axis laser cutting, it’s all about flexibility and speed.
The flexibility to cut thick plate one day; exotic alloys the next and parts with intricate shapes the next. Our laser systems are in a word, flexible. Flexible to adapt to your ever-changing processing needs. Flexible to perform the simplest to most demanding cutting jobs.
Our 5-axis laser cutting systems also give you speed. With rapid feed rates to 1,575 in/min and cutting feed rate to 1,181 in/min and accuracies of ± 0.0012 in. per 12 inches of travel, Komatsu Laser sets the standard for 5-axis laser cutting.
So whether you’re cutting titanium on Monday, mild steel on Tuesday or galvanneal or Wednesday, think of Komatsu Laser as your laser cutting resource.
www.ntclaser.com 248-859-4373
Looking for Fine Plasma or Laser?
Fine Plasma
MORE POWER
MORE FLEXIBILITY
MORE OUTPUT
The new Komatsu TFP does all this and more.
300 Amps of Fine Plasma Power to cut 40mm (1.6˝) mild steel at 45 IPM and the finesse for 1.6mm (16ga.) at 200 IPM. PLUS switch to Oxy cutting 2˝ thick plate in less than 30 seconds by a simple nozzle change. And with only 1-cutting head there is no “dead zone” on the table so you can nest plates using the full table size.
5-Axis Laser
Komatsu is your single source for all your cutting needs
Mon.
Titanium (0.030 in.)
Tues./Wed.
Mild Steel (0.050 in.)
Thurs.
Galvanneal (0.039 in.)
Fri./Sat.
Aluminized Steel (0.046 in.)
TLM Series of 5-axis,
3-dimensional laser systems ideal for cutting complex contours and shapes.
TLV Series 3-axis hybrid
machines for large and wide workpieces.
TLX Series high-power
3-axis in cantilever and gantry configurations.
TLH Fiber Laser 5-axis,
3-dimensional laser cutting systems for ultra high speed and versatility.
