Page 17 - MetalForming February 2017
P. 17
When it tak
es off,
, al quality
Admir
r
Over 65 years of quality and dependability go into all of our
ides along.
carbon and alloy steels. Y
trust Admiral’s tradition of first-class quality, on-time delivery, and personalized service. Contact us for a quote today!
our p parts and components demand
o
craft quality 4130, or any of our AMS-certified low and high carbon alloy steels,
the same commitment. Whether it’s air
TM
est 123rd Str
Ph: 800-323-7055 Fax: 708-388-9317
email: sales@admiralsteel.com
ed trademark of Admiral Steel LLC. Alsip, Illinois. Reg. No. 2430959. All rights reserved.
A
alsteel.com ISO 9001 REGISTERED
A
d
d
m
i
e
eet Alsip, Illinois 60803-1869
ir
4152 W
Admiral is a r
egister
TruDisk solid-state laser, as well as a laser-cutting system, a laser evacuation unit and a beam-guard system.
The machines offer a completely redesigned drive technology, dubbed Delta Drive, to move the electric punching head and the laser along the Y axis while the sheet moves in the opposite direction. Powered by two servomotors, this arrangement enables the machine to accelerate far faster in the Y axis and eliminates the need to move the sheet or worktable.
Also included: automatic sorting of finished parts to 7 by 7 in.—parts move sent down a chute and can be sorted into a series of four boxes positioned below the machine.
Trumpf: www.us.trumpf.com
North American Debut of Amada’s New Robotic-Bending System
The HG 1303 Rm robotic-bending system from Amada, which made its North American debut at FABTECH, was designed specifically for processing large parts that typically require two operators to safely handle, or are difficult to manage by a single operator. The HG 1303 servo-hydraulic press brake features an advanced crowning system in the lower beam, combined with an automatic bend-angle measurement system to ensure optimum accuracy. Its Dual Servo Power (DSP) drive system maximizes approach, bend and return speeds, and a new, highly rigid frame design features (reportedly) a larger open height than other machines in its class. The increased distance between tooling and greater stroke length yields a large processing area and enables deep box bending while making part extraction quick and easy.
Included with the press brake is a thickness-detection system (TDS) designed to maintain bending accuracy while processing materials that vary in type, thickness and grain direction. The TDS senses any variation in material thickness and automatically compensates ram-depth position to ensure precise bending results. Amada’s HG series brakes also are equipped with BI (Bend Indicator) sensors that use probe and laser technology. BI-S (probe type) or BI-L (laser type) sensors result in trial-free bending. BI technology also boosts repeatability and reduces inspection and rework requirements.
Amada America, Inc.: www.amada.com
manufactures mechanical and CNC
ertslides to produce a variety of metal and wire
formed parts from simple stampings to complicated assemblies using a multitude of options such as tapping, welding, and automated assembly. Represented in North America by Gibraltar Corp.
v
v
e
(continued on page 38)
MetalForming/February 2017 15
