Page 45 - MetalForming February 2017
P. 45
Robotic-Tool-Change Systems
the ground up to cut thick plate (to 1.18 in. with consistently high quality), as well as meet the demands of high-speed sheet- metal cutting. The triangular cutting-bridge design provides optimum rigidity and accuracy.
to insert express jobs and residual sheets at any time, even while large-scale jobs are running. The machine uses Bystronic’s ByVision cutting process that unites all of the critical functions on a 22-in. touch- screen and provides the operator with numerous possibilities to interactively intervene in the cutting process. Bystronic: www.bystronicusa.com
Stäubli leveraged its 60-plus years of experience in connection technology with its FABTECH 2016 booth displaying the latest in robotic-tool-change systems, and emphasizing its soon-to-be-released MPS 260 robotic tool changer. Designed for a range of applications including welding and material handling, the robust tool
Optimizing versatility, access to the cutting area is via the long side of the machine. A large sliding door allows users
Wo
or
rkh
ho
oldi
ing
g C
Cl
la
a
am
mp
ps
changer features multiple couplings for air/vacuum connections, and can be equipped with connectors for data and electrical transmission. Very compact dimensions, with a coupled height of only 67 mm, make the MPS 260 the first choice for applications requiring a high number of mating cycles, according to company officials. As the accompanying photo shows, the tool-change module ensures steady, careful handling of heavy yet delicate loads. The MPS, for example, can handle loads weighing to 350 kg. Stäubli: www.staubli.com
8- and 10-kW
Fiber-Laser
1-800-624-8511
phdinc.com/mf217
Cutting Machine
Bystronic introduced the ByStar Fiber laser-cutting machine, available with a 6-, 8-, or 10-kW power source, designed from
MetalForming/February 2017 43
