Page 14 - MetalForming March 2017
P. 14
Flexible Roll-Up and Laser-Welding Module for Stainless-Steel Drums and Baskets
the sheet into a hoop-shaped wrapper. The joint then is laser-seam-welded in a single operation, eliminating double han- dling of the part as in traditional processes. Laser welding can be performed using CO2 or fiber lasers; the process includes inline scanning and inspection of the weld joint.
Coldwater Machine Co.: www.coldwatermachine.com
Peening Promises
Polished Tools
Quickly, with
systems can be customized to suit customer requirements.
Coldwater has automated the process from coil stock to finished basket or drum
Optimum Properties
with a flexible and modular approach that allows on-the-fly automatic changeover to different part diameters and heights, for optimum overall equipment effectiveness (OEE). The process begins with a servo-controlled decoiler that feeds stainless steel through a straightener into a proprietary trimming press. Here the material is sheared to the specified sheet lengths, and edges are prepared for laser welding.
German-based company accurapuls (with North American offices in Edmonton, Alberta, Canada) has developed the micro- cold-forging (MCF) process for improving the surface finish of dies and molds. Aimed at the automotive industry, the
The material automatically feeds into the roll-up and laser-weld module, which rolls
Coldwater Machine Co., a manufacturer and integrator of assembly automation and special machines for the appli- ance, automotive and aero- space industries, announces the availability of a roll-up and laser-weld module for the fab- rication of clothes washer and dryer drums and baskets, or other round sheetmetal wrap- pers. Based on a standard Coldwater-developed process,
   12   13   14   15   16
