Page 44 - MetalForming May 2017
        P. 44
     Die Development and Simulation Software
  Needless to say that the time consump- tion will only increase if the user is try- ing to identify a complicated or a non- existent solution.”
Optimization might be one way to overcome the limitations of a trial-and-
error approach. “Most of the optimiza- tion tools run a loop of iterations until a good result is found,” Ramamurthy adds. “Optimization is selection of the best input value with regards to some criteria (thinning of 25 percent, for exam-
ple). It loops through several iterations of the input to give an optimal value of thinning. If there are multiple results targeted, optimization becomes more time consuming and complex; or a solu- tion can never be identified. With mul- tiple ‘sensitive’ inputs, it becomes increasingly important to identify if there could ever be a solution associated to a simulation. Depending on the inputs, it’s possible that the simulation might never have a solution if certain input parameters are flawed. So a bad result is as important as a good one.”
Ramamurthy will describe the use of systematic process improvement (SPI) and a robustness check of a virtual stamping process. Learn how new sim- ulation software employs automat- ed/manual issue detection to identify local forming windows, and then pro- poses a combination of design variants to address these issues.
“An entire range of input variables can be checked for a feasible ‘green’ simulation,” Ramamurthy says, “and
          Uncove
U
er
r
D
D
esig
g
gn Fla
aw
                th S
YNAFORM
t
a
ping S
Optimize Mater
s on
S
ta
m
m
p
S
Si
i
i
m
m
ul
l
a
a
t
w
s
 ti
           w
i
w
i
i
t
  r
Uti
ation
i
i
a
al
l
l
l
i
i
z
z
     P
sues
Pr
re
edict
orma
y Develop the Trim
tF
F
a
b
bi
i
lity
I
I
s
s
    ml
 l
l
y
y
p
pr
r
i
k
l
li
i
ine
               An
ze S
YNAFORM Today
a
ingback
a
                      Sponsor of the
Die Design Software & Simulation Technology Experience May 31 - June 1, 2017 in Chicago, IL
             D
Y
Try D
www
                   .eta.com/
D
      Die System Simulation Solution
YNAFORM
  42 MetalForming/May 2017
