Page 14 - MetalForming June 2017
P. 14
offered in thread
sizes 4-40 to 1⁄4-20 and
M3 to M6, and in lengths from
0.187 to 1 in. and 4 to 25 mm.
Sheet preparation for installation
requires only a blind milled hole
to the recommended size and min-
imum depth. Using a Pemserter or other standard press, installation is simple: Place the fastener in the hole and apply sufficient squeezing force. The fastener head then locks securely in the sheet and can handle substantial loads.
All PEM concealed-head fasteners are RoHS-compliant and selected stud types can be ordered to NAS63540/4 specifications.
Penn Engineering: www.pemnet.com
Versatile 100-Ton Press Targeted Toward Packaging Industry
Imagine the versatility of a single press platform that can be configured for either a shell or cupping application. That’s the versatility afforded by the new MP1-90 portal press from Nidec
Minster Corp., Minster,
INCREASE PRODUCTIVITY THROUGH MODERNIZATION.
MODERNIZATION OF ALL SCHULER PRESSES FOR MORE PRODUCTIVITY.
Our Services - your benefits:
Increase productivity of the press Improved equipment availability
Spare part availability
OEM specifications
Latest legal specifications
State-of-the-Art technical specifications Enhanced OEE
SCHULER INC.
7145 Commerce Blvd. Canton, MI 48187 Phone 734.207.7200 info@schulerinc.com www.schulerinc.com
OH."Wesoughttooffer a low-cost, robust, durable and reliable press for this seg- ment of the metal-packag- ing industry," says company CEO David Winch. Rated at 90 metric (100 U.S.) tons, the MP1-90 press is capable of 250 strokes/min. in shell applications and 150 strokes/min. in cupper mode. The press also features a 100- mm shut-height adjustment, and a cast-iron frame and forged steel crankshaft that minimize deflection. Oil-film bearings give the press precision bottom-dead-center repeatability, while the combination hydrostatic/hydrodynamic guiding system allows for precise slide guiding, infinite bearing life and optimized part
quality.
The MP1-90 press includes a Minster pneumatic clutch and
brake with a proven record of long life and dependability. A hydraulic-overload feature in the slide protects the press frame and components in case of an overload condition.
Nidec Minster Corp.: www.minster.com
12 MetalForming/June 2017
