Page 18 - MetalForming June 2017
P. 18
Materials & Coatings
Process Deposits Ultra-Hard Coatings to Inside and Outside Part Surfaces
throughout his career and we look forward to John leading more advanced product and manufacturing technology projects as the partnership advances.”
Duralar Technologies, Tucson, AZ, developer of advanced, ultra-hard metal coatings and coating machines, has introduced the Duralar CS-50 deposition system, able to coat both the inside and outside surfaces of metal parts using a proprietary process called DualArmor.
The A/SP works to develop lightweight steel solutions to meet the current and future needs of automakers.
“The CS-50 system features a tubular processing chamber that opens like a clamshell, allowing metal parts to be placed inside for coating,” says Duralar CTO Tom Casserly. “DualAr- mor coating employs a unique hollow cathode plasma- enhanced chemical- vapor deposition process to bathe the parts in an extreme- ly intense plasma— roughly 1000 times greater than a standard CVD plasma. This enables parts to be coated at a high rate. Also, the chamber eliminates the line-of-sight limitations experienced with spray-type coatings. Since all deposition occurs within the dense plasma, all part surfaces receive a uniform coating, eliminating the need for post-
Corrosion-Inhibitor Packaging Film
processing rework."
The CS-50’s unprecedented deposition speed enables the use of thicker hard
coatings than were previously technically possible or commercially feasible. Previously, conventional diamond-like carbon coatings had a practical total thickness limit of around 5 μm; Duralar DLC coatings can be 50 μm or more.
DualArmor coatings reportedly can provide 5 to 10 times the hardness of carbon steel and more than 10,000 times greater wear resistance than Type 304 stainless steel. The coatings feature high levels of corrosion and erosion resistance, and they are virtually frictionless, with a friction coefficient of less than 0.08.
Duralar: www.duralar.com
New Executive Director for Auto/Steel Partnership
chemistry proven effective for protecting valuable metal components during storage and shipment. The transparent, heat-seal- able, recyclable film has excelled in rigorous testing to international standards, including German product health and safety regu- lation TRGS 615.
The Auto/Steel Partnership (A/SP), a 30-year collaboration of auto companies and steelmakers, announced that John K. Catterall, an automotive-engineering veteran in body-structure, chassis and closure applications, has been named executive director. Prior to joining the A/SP, Catterall held the position of global innovation manager for body systems at General Motors Co.
“With the resurgence in the automotive industry, I look forward to growing the A/SP and elevating its importance,” says Catterall. “I’ve spent nearly four decades running advanced development projects with General Motors Co. and other organizations. My knowledge and experience will help us to be more efficient, and work more collaboratively with our members to grow the A/SP in the years to come.”
Clear Pak Bio is designed to prevent corrosion of ferrous metal alloys using advanced VCI chemistry derived from plant extracts that are nitrite- and amine- free, and non-toxic. The flexible, punc- ture- and tear-resistant film is tinted a unique shade of purple.
Says Steve Gallagher, body structures technical specialist at Ford Motor Co. and chairman of A/SP’s Joint Policy Council: “John has been an active member in the A/SP for many years and his working knowledge of the organization, as well as his deep understanding of the automotive industry made him the right candidate for the position. He has held leadership roles in several major automotive technology projects
Daubert Cromwell: www.daubertcromwell.com
16 MetalForming/June 2017
Corrosion-prevention specialist and manufacturer Daubert Cromwell, Alsip, IL, introduces Clear Pak Bio corrosion inhibitor (VCI) film, an effective and envi- ronmentally safe protective packaging film for industry. Clear Pak Bio uses pro- prietary, plant-based corrosion-inhibitor
