Page 16 - MetalForming September 2017
P. 16
freeing up space on plant floors. Direct-drive motors such as those in the SGM7F line allow for attaching a load directly to the servo motor, enabling a full range of motion control without the need for a shaft coupling or gearhead. SGM7F also offers a high torsional stiffness and virtually eliminates mechanical backlash, according to company officials. This yields
an output that minimizes damage to components and maximizes posi- tioning accuracy and repeatability.
Other features:
• Open-core design that adapts easily to shaft mounting and allows wiring to pass through easily
• 24-bit encoding for precise motion control
The best tooling is American made!
You may not think there’s much difference in tooling for stamping and roll forming, but with our precision punches and buttons, you’ll also get our commitment to provide you the best tooling, at the right time, for the right price. We’ll work hard to help make your operation more efficient and more profitable. Isn’t it time to choose a tooling supplier that really is different?
Because there really is a difference!
www.AmericanPunchCo.com
800.243.1492 info@AmericanPunchCo.com
• Self-cooled design that generates a low level of heat
• Compact size and high torque, making it ideal for applications requiring downsizing and shorter cycle time
The SGM7F line offers eight different models to suit a range of industrial appli- cations, including transfer lines, die actu- ators, electronic-parts assembly and dial tables.
Yaskawa America, Inc.: www.yaskawa.com
Spray-Lube System
Saves Electrolux
Barrels Upon
Barrels of Lubricant
Italian appliance manufacturer Elec- trolux, in its efforts to automate its stamp- ing-lubrication processes, has invested in a Sagoma-series adjustable-spray lube system from DIetronic. The investment is in keeping with the company’s consum- able-consumption goals, says an Electrolux
14 MetalForming/September 2017
