Page 34 - MetalForming September 2017
P. 34
32
MetalForming/September 2017
For Punching or Drilling We Have A Machine For You
Engineers at Bretford Manufacturing, familiar with the automatic panel bender’s capabilities, design parts and products specifi- cally for this equipment.
Huge Productivity Uptick
Running 20 hr./day during the busy summer season, the reliable P4 has streamlined panel-bending operations.
“We’ve found that the panel bender offers an advantage over the press brakes in certain operations,” Raddatz says. “Whereas the P4 averages 45 sec. to make a part via auto- mated setup and tool change without ever missing the back- guage, the same part would require two press brakes, and two different setups. The quantities are just off the charts as compared to using the press brakes for some of these operations. Once programmed, the P4 does the work correctly every time, so you just need someone for loading or unload- ing. Conversely, a press-brake operator would need to know how to flip the part, understand the bending sequence and a lot more. The payback sold us.”
Santaromana is quick to agree.
“The press brakes can do some things that the P4 can’t, but the P4 does not require setup and it performs automatic tool changes,” he says. “And, it can perform accurate radius bends automatically and much more quickly than on a press
Shown with Optional Press Brake
Gap-Bed Hydraulic Punch Press...
TheGBseriesisidealasadedicatedpunchpress,but easily accepts a wide range of standard accessories and special tooling to allow shearing or forming. Double your production with the DPI series... Back-to-back hydraulic punch presses with a single power source and separate controls.
See us at
FABTECH Booth A3052
All brands, all manufacturers will be considered for trade in / trade up
Kalamazoo Metal Muncher
Phone: 269-492-0268
Email: info@kalamazoometalmuncher.com Web Site: www.kalamazoometalmuncher.com
100% Made in the USA
Heavy-Duty 20" Drill Presses...
•Heavy-DutyCastIronConstruction • Mechanical Variable Speed
• 2 Speed Range Models Available • Drilling Capacity Up-to 1-1/4"
• Optional Programmable Macro-Drilling Power Feed
Automatic Panel Bending
