Page 16 - MetalForming October 2017
P. 16
can be produced quickly over a 3D surface in a single setup, and they can be drilled at steep angles and in difficult-to-machine materials. SmartPerf also is used for pro- ducing hole patterns involving trepanning and standard precision drilling. Common applications involve drilling a pattern around a pre-existing machined feature and creating custom spray patterns based
on an array of non-uniformly spaced, sized and shaped holes. It makes possible new laser-drilling applications such as fuel filters and noise-abatement panels. Prima Power Laserdyne: www.primapowerlaserdyne.com
Swing Shear Offers
Reduced Maintenance
and Precision
Coe Press Equipment announces the availability of its oscillating Servo Shear. Compared to hydraulic shears, the offering is designed to significantly reduce main- tenance time and costs due to the absence of some components and much of the lubricant. The shear is engineered to cut rectangular and trapezoidal blanks with repeatable precision, and its smooth motion is quieter than a conventional shear.
SPEED UP YOUR DIE CHANGE
AFTER: 22 ft-lb
BEFORE: 400 ft-lb
Hydro-Mechanical Clamping Nut
NO MORE CHEATER BARS.
The manually operated Hydro- Mechanical Clamping Nut generates a safe, repeatable clamp force of 11 tons with a standard ratchet wrench. A unique indicator pin assures safe clamping.
hilma-usa.com
Booth #A5319
Fenton, MO 63026 800-827-2526 Carr Lane Roemheld Mfg. Co. Email info@clrh.com
14 MetalForming/October 2017
“By eliminating the hoses, fluids, air, clutch and all the energy associated with hydraulic systems, this product offers our customers many advantages,” says Steve Donnay, director of sales and marketing.
The shear is self-contained, and relies upon a slew ring to support the weight of the shear. This design allows the shear to swivel in back and forth with the help of a second servo axis, attaining different angles for the cut. It can handle coil mate- rials from 24 to 78 in. wide, to 0.25 in. thick. When run in continuous mode, the system is capable of reaching speeds to 240 strokes/min., depending on the width of the material.
Energy savings is another benefit of the system. Since gravity has little effect on a servo motor in a resting state, little energy is required to hold in a balanced position between cycles.
Coe Press Equipment: www.coepress.com
