Page 14 - MetalForming-Feb-2018-issue
P. 14
 its X1 and X3 models, the X5 units feature a large 12-in. touchscreen as well as Tool Memory that stores data used for precise machine setup for repeated production runs.
as well as part or tool variations, enabling manufacturers to optimize machine effi- ciency, improve part quality, and limit unplanned downtime and tooling costs.
The trend toward lightweight construc- tion and increasing part complexity can result in higher deformation levels. These units help identify manufacturing faults
Here’s how the X5 works: Sensors in the machines, positioned to convert energy into electrical signals that monitor tool and machine performances from applied forces, provide the systems with information
  Tons of Hydraulic
Metalforming, Compression Molding
Challenge
Design and build a highly versatile, precise press for metalforming and compression molding applications.
Solution
Open, 8-pt. gib-guided straight side press offering multiple tonnages, separate stroke parameters and precise repeatability.
Results
Substantially improved quality, accuracy and productivity, with application flexibility.
Pressing for the best solution
American Made
Press Solutions!
       Scan to See Our Story
From 3 to 40,000 Ton
Rely on Greenerd
 800-877-9110 • www.greenerd.com
to solve your next pressing challenge.
 12 MetalForming/February 2018
used to learn the normal limits of the process. The control unit then observes the signals of each cycle and compares those with the stored curve. When the signal moves outside of the envelope curve, the formed part is sorted out, or the machine is stopped.
Each X5 allows the user to input the type of machine monitored and features eight channels for sensor signals displayed as maximum forces, envelope curves and trend progressions. Additionally, six zoom channels offer detailed monitoring of spe- cific, sensitive process areas such as dis- torted parts or a short feed.
Marposs Corp.: www.marposs.com
or www.brankamp.com
New Quick-Die-
Change Catalog
Available Online
The Hilma division of Carr Lane Roemheld, Fenton, MO, has published its new edition of the Quick Die and Mold Change catalog, featuring a variety of clamps and lifters, cylinders, power units and valve packages.
Hilma systems are universally adaptable and permit safe, rapid change-over to new production lots. The systems provide a high degree of clamping force control, according to company officials, enabling just-in-time production. Other advantages include increased uptime, reduced labor, faster delivery, faster turnaround and reduced inventory.
To download a catalog, visit www.hilma- usa.com
   12   13   14   15   16
