Page 18 - MetalForming-Feb-2018-issue
P. 18
 16
MetalForming/February 2018
• Thefineststraightoils,specialty oils, vanishing oils and water soluble oils
• Oil-freelubricants
• Theexpertisetomaketheperfect
selection for any job
• Chlorine-freelubricants
See how Lamson can help your operation!
Theright lubricantcanhaveahuge impact on production rates and part quality.
Stamping the upper and total die weight on the die is the required method, unless the company can make available a foolproof alternative, such as written instruction—including the
Tooling by Design
must lift after the press has gone through the bottom of its stroke. This permits all of the electric motor’s ener- gy to go toward regaining flywheel speed that was lost stamping the part rather than wasting
upper-die weight. OSHA requires that the weight be stamped and not marked or painted because stamping this infor- mation eliminates the risk of repainting an incorrect figure on the die.
the motor’s energy on lifting the ram.
Retrofitting older presses with integrat- ed controls having tonnage-monitoring capabilities together with automatic shut- height and counter- balance adjustment functions can greatly improve die-setting time, accuracy and
consistency.
Are you interested in learning more
about die-setting practices and safety? Then consider attending PMA’s Die Set- ting Practices and Safety seminar, Feb- ruary 21-22, 2018, in Nashville, TN. Visit PMA’s website to register or con- tact Marianne Sichi msichi@pma.org for more information. MF
How important is counterbalancing?
Important enough
that OSHA requires
information regard-
ing upper die weight
be made available to
the die setter to
enable proper counterbalance adjust- ments. The total die weight of the die assembly also must be known to avoid overloading die-handling equipment.
Are you getting your e-news?
SENSORS
for punching, formin & process monitoring
Vester Elektronik Gmb
MetalForming magazine publishes a bi-weekly e-mail newsletter for the metalforming industry. Stay informed of the latest occurrences within our industry, and keep tabs on the near-term plans of MetalForming and the Precision Metalforming Association. With each issue you’ll find unique articles describing metalforming in action, as well as links to industry articles. We’ll also fill you in on the magazine’s current- and future-issue content.
You can get it delivered but you need to request it. Just go to www.metalformingmagazine.com
and click on “Subscribe to our e-newsletter.”
t’s just that simple.
Sensor Technology
 Process Monitoring
www
est
.v
er
Understanding hazardous energy and closely following company procedures related to lockout-tagout during
die change are crucial.
.de / us
ee catalog on demand !
Fre
   16   17   18   19   20
