Page 28 - MetalForming-Feb-2018-issue
P. 28
 family of companies, joining Yorkshire CNC and Ingenium Integration. The joint venture will strengthen Unison’s portfolio adding a range of bending machines for small-diameter tube and wire.
torque sensors in all joints constantly monitor force to quickly react to contact; something typically only found in more expensive systems, according to com- pany officials. It is designed to eliminate operator pinch points while through-arm utilities hide cabling
Jagemann Adds Machining Center
Jagemann Stamping Co., Manitwoc, WI, announced its purchase and installation of a Kitamura machining center for more inhouse, value-added services.
and increase safety by reducing the risks of snagging or inter- ference with other equipment.
Six-Axis Collaborative Robot
In addition to traditional robot pro- gramming through a teach pendant, users can hand-guide the HC10 robot when teaching new program paths. This feature allows the robot to be quickly deployed or redeployed on demand, decreasing system downtime and increasing return on investment. Whether operating at full
or collaborative speed, cycle times are optimized based upon risk assessments and process requirements.
The new six-axis HC10 collaborative robot from Yaskawa Motoman, Dayton, OH, works safely with, or in close proximity to humans, as the robot will stop in the event of contact with an operator. Dual
The highly configurable HC10 offers a 10-kg payload and 1200-mm reach, and can perform a range of material-han- dling, machine-tending, packaging or light- assembly tasks.
Yaskawa Motoman: www.motoman.com
      Made to Handle Metal.
                               We help you make
things faster, safer... better.
Industrial Magnetics, Inc. fabricates innovative and unique magnetic solutions for industrial lifting, holding, fixturing and moving applications as well as a wide variety of conveying products for ferrous metal parts, lids, containers and more.
Plates, Pipes, Parts... No Problems!
888.582.0823 • www.magnetics.com
     26 MetalForming/February 2018
   26   27   28   29   30
