Page 41 - MetalForming-Feb-2018-issue
P. 41
   All-New Bliss Lineup
Visitors to the Schuler booth witnessed the new 125- metric-ton Bliss stamping press equipped with a new Bliss coil-feed system. Up and running on the show floor, the C1-125 single-point gap-frame mechanical press features
 Allen-Bradley controls, a fast-acting hydraulic-overload sys- tem, Ross valves, Siemens drive motor, Graco lubrication, an OMPI clutch and flywheel brake. The standard configu- ration attains 30 to 60 strokes/min; the model B300 compact coil-feed system feeds stock to 300 mm wide.
Bliss Press USA: www.blisspressusa.com
Preconfigured Welding Pakages
Kuka‘s new ready2_use preconfigured welding packages drew the attention of FABTECH attendees. The solutions, which can be integrated into existing production environ- ments, include the ready2_arc package that combines Kuka KR Cybertech nano and KR Cybertech arc nano robots with Miller Auto-Continuum 350 and 500 power supplies. This package is for typical welding tasks—thin to thick sheet car- bon steel, aluminum or special welding modes for root- pass, narrow-gap or deep-penetration welding seams. The Kuka ready2_spot uses servo guns for the quick and easy implementation of spot-welding applications when joining steel and aluminum parts.
Kuka: www.kuka.com
Fabrication: FABTECH
                         RAMPIN
G
G
     UP RODUCTION?
P
                               PR
R
R
ANCE WELDING
MA
READ
.COM | USEDSPO
CHINER
RESIST
A
     Y & MORE,
Y FOR IMMEDIAT
SHIPMENT.
Y
                         TE
MetalForming/February 2018
39
TJ
-SNO
JSNO
W
W
T
. WELDER.COM | (80
0) NO
W
   39   40   41   42   43
