Page 45 - MetalForming-Feb-2018-issue
P. 45
Air-Cooled Robotic-Welding Torches
Abicor Binzel debuted its Abirob Cyclone for air-cooled robotic-welding applications. The offering enables opti- mal current transfer to the torch with-
folds and exhaust pipes, and the com- pany’s full-electric and multi-stack CNC tube-bending machines allow for a range of different tube and profile dimensions to be bent. Users benefit from short cycle times, high speeds and high accuracy, according to com- pany officials. In combination with individually adjustable tools, multi- level technology reportedly enables problem-free and accurate shaping of
tubes even with short lengths between individual bends. The CNC 100 E TB MR can be used to bend exhaust pipes with a bending radius of only one times the pipe diameter. Its integrated rapid- clamping system, Quick Tool Unlock, allows rapid changing of bending tools. This helps optimize setup time and reduces machine downtime. Schwarze-Robitec: www.schwarze-robitec.com MF
Fabrication: FABTECH
W
ing
Wo
o
r
rk
kho
l
ld
i
g
C
Cl
lamps
out loss of amperage to meet the demands of high-production opera- tions, while its torch neck rotates end- lessly in a full 360-deg. rotation.
The modular design enables easy assembly/disassembly and mainte- nance. In addition, the company stress- es that the Cyclone technology, when used with robotic-welding cells, will result in less wasted motion, higher production and reduced part cost. Abicor Binzel: www.binzel-abicor.com
Automated Tube and Pipe Bending
Schwarze-Robitec, with new office and warehouse facilities in Grand Rapids, MI, showcased its range of
Series GRM Sheet metal
C5091
er
Se
RM1
C
t
ie
es GR
Com
m
p
pa
ac
c
t
t s
sh
h
he
e
e
e
et
assembly
tube- and pipe-bending machines as well as fully automatic bending cells. The booth featured a state-of-the-art CNC 100 E TB MR tube-bending machine in action. The machine allows for production of different radii or bend-in-bend systems, such as mani-
1-800-624-8511
MetalForming/February 2018 43
for more information, visit:
phdinc.com/clampad
