Page 13 - MetalForming-Mar-2018-issue
P. 13
plastic and fiber drums. The company’s offerings can handle capacities to 1000 lb. per drum and provide various lift heights. Straddle-leg and counterbalance configurations as well as spark-resistant and EE/EX-specification packages are available.
Liftomatic Material Handling, Inc.: www.liftomatic.com
The best tooling is American made!
You may not think there’s much difference in tooling for stamping and roll forming, but with our precision punches and buttons, you’ll also get our commitment to provide you the best tooling, at the right time, for the right price. We’ll work hard to help make your operation more efficient and more profitable. Isn’t it time to choose a tooling supplier that really is different?
Because there really is a difference!
www.AmericanPunchCo.com
800.243.1492 info@AmericanPunchCo.com
switch, WaveFormPac tonnage signature monitor, WPC 2000 Clutch/Brake control and others. In addition, the Wonderware hosting option enables the SmartPac Pro to run independently created third-party HMIs for associated automation, reducing the number of screens required on the press.
The control’s new tool-summary screen enables users to view the entire contents of each programmed setup on a single screen, provides a place for users to place notes for each job, and can be exported to a USB disk as comma-separated values. Users can create custom homescreen dashboards to display the information they use most often, name the dashboards and save them in the favorites menu for quick recall.
Wintriss Controls Group: www.wintriss.com
Portable Drum
Handlers Ease
Transport
Liftomatic Material Handling, Inc., Buf- falo Grove, IL, has introduced the Ergo- Matic line of portable drum-handling equipment. The line, featuring fully modular designs for efficient manual handling of a single drum, comprises a range of models for repetitive applications. Features include high-lift capability—to 36 in.—for double-stacking of drums, spark-resistant components for flammable areas and double Parrot-Beak clamps for fiber and plastic drums. Off-the-shelf and customized equipment are available.
Products from Liftomatic range from hand trucks to fully powered lift, lower and position devices, suitable for steel,
MetalForming/March 2018 11
