Page 24 - MetalForming-Mar-2018-issue
P. 24
end configuration to 5⁄16-in. dia.
The M-Brad aluminum-oxide, 6.12- nylon microfilament evenly encapsulates various abrasive grit particles on the sur- face as well as throughout the nylon fila- ment. The flexibility of strands makes it uniquely effective when deburring complex parts. It reportedly yields consistent gradual cutting action, permitting precise control
REDUCE WORKPLACE ACCIDENTS up to 25% with PRAB Conveyors
in applications ranging from cosmetic surface preparation on brass or soft aluminum, to edge blending on mate- rials such as titanium and carbide. In addition, M-Brad brushes report- edly yield longer tool life than non- woven synthetic abrasive products, and are suitable for wet and dry surface con- ditioning, although the use of coolant is
recommended.
Pferd Inc.: www.pferdusa.com
Instant Data Transfer of Band-Saw Blade-Cutting Parameters to Machine
DECREASE
forklift traffic
MINIMIZE
Safety Risks
Simonds Saw, Fitchburg, MA, a man- ufacturer of band-saw blades and files, announced that its European partner, Wespa has introduced the ability to produce instant blade-to-machine data transfer of machine-specific cutting parameters for its Individual Performance Cutting (IPC) custom-band-saw-blades program. By using a mobile device and scanning a QR code on the saw blade or blade box, saw operators can point the scan to the machine to transfer a complete, unique data set so that the machine can begin cutting.
Stamping Scrap Conveyors
ELIMINATE
scrap contact with operators
Pivot
Belt Conveyors
Steel
Belt Conveyors
IPC from Simonds Saw uses a band- saw blade-simulator program to reportedly improve sawing productivity by as much as 60 percent by significantly improving the performance, productivity and return on investment of a user's sawing operation. The simulator enables users to model their sawing applications and compare the results obtained with conventional saw technology to unique blade/tooth configurations designed specifically by Simonds/Wespa for users’ applications. Simonds Saw: www.simondssaw.com
See how to minimize safety risks with PRAB automated conveyors.
888-324-2576
Minimize your risk at:
prab.com/mf
a
company
22
MetalForming/March 2018
