Page 14 - MetalForming-Apr-2018-issue
P. 14
or electric discharge machining (EDM), which creates a white layer during the hardening process that weakens the casing. Because the EDM or burning process micro-hardens the very edge of those casing characters, it changes and weakens the molecular structure of the material, making it easier for characters to chip away.
Forming on the other hand, stamps the characters into the brass casing, which creates a stronger molecular bond in the brass. This delivers a better surface finish, more polish and a stronger molecular capacity, which creates a higher quality brass casing.
turers using the forming process for cre- ating premium rounds and meeting the quality standards expected by military and law-enforcement organizations. Using bunters designed and manufactured for forming rather than for burning delivers tighter tolerances and a clean, smooth finish. Characters on each individual brass casing appear identical to one another, whereas the EDM process leaves slight variations.
Repeatability and consistency are additional benefits gained by manufac-
T
While bunters and head stamps are relatively straightforward to use, different machines often call for different approach- es to maximize production and prolong tool life. When implementing form tooling, ammunition manufacturers can take a variety of approaches depending on the type of machine in the shop, whether using a flywheel on a ram, a turret press or traditional stamping press.
TH
H
E
E
T
TI
I
M
M
E
EI
IS
S
N
N
O
O
W
W
Speed up your Quick Die Change.
Let Hilma help you achieve Single Minute Exchange of Dies.
Visit www.hilma-usa.com/quick-die-change
Carr Lane Roemheld Mfg. Co. · Fenton, MO 63026 Phone 800-827-2526 · Fax 636-386-8034
Some machines simply perform bunting applications better than others. In turret systems, a vertical tool setup often provides longer tool life because compression occurs at a more consistent pace. Conversely, ram-style systems deliv- er a brute force in this application, with mechanical results that may not be 100- percent consistent.
Process and Steel Pairings
Machining and tool steels have come a long way since the 1950s and ’60s. Then, tooling manufacturers commonly used O1 or A2 steels, acceptable for the consistent and universal processes used to manufacture ammunition. Some advanced machining techniques used today, however, such as milling, grinding or turning, now are applied to the ammu- nition industry. Considering the different tool steels and how individual steels func- tion during a drawing process, or a trim or process, helps determine how the steels respond to different stresses, which helps toolmakers create custom tools designed for different applications.
For example, a draw-tooling application requires a tool steel that can withstand the stress of material stretch, maintain its final form and be flexible while expe- riencing extra pressure. Turning a part,
12
MetalForming/April 2018
