Page 33 - MetalForming-Apr-2018-issue
P. 33
BDC and top dead center—no addi- tional force required during press restarts. (A key press-design enhance- ment that allows repeatable stop-start cycles at full tonnage at BDC: proper lubrication of the bronze bushing with- in the press crown.)
These findings verify that press con- ditions at BDC are well suited to a con- tinuous hot-stamping process, with the required control of ram position and force on the part and die without a meas- urable increase in power consumption.
Case Study: Automotive-Parts Supplier Batz
While hydraulic presses originally got the call for hot-stamping lines, the Spanish automotive supplier Batz can testify to the benefits provided by servo-mechanical presses. It has used a 15,000-kN Fagor servo-mechanical press (3.6 by 2-m bed) for hot stamping since March 2016—for die tryout and production. The company uses hot stamping to produce primarily safety- related parts from boron steels, and employs production lines outfitted with robotic destackers, roller or walking- beam furnaces, robotic unloading to conveyors, and laser or press trimming.
With two years under its belt using the servo-mechanical press in hot- stamping die set-up and preserial pro- duction, Batz now has a clear idea as to press performance in this applica- tion. Energy savings was an immedi- ately identified result.
“Energy consumption was one log- ical and expected advantage,” explains Andoni Alonso, hot-forming business manager for Batz. “With hydraulic presses in our facilities, we were used to their high energy consumption. With this servo-mechanical press, energy expenses have dropped dramatically and this is something to take into account nowadays.”
More surprising was the equip- ment’s effect on part quality.
“During the set-up of new dies, we realized that we could more easily achieve higher-quality parts than in our conventional hydraulic presses,” Alonso says. “We attribute this in part
to the higher drawing speed of the servo-mechanical press. The servo con- trol also allows us to simulate the end user’s press conditions, which ensures that part quality at a customer’s facility will be comparable to ours.”
Alonso advises that proper training is necessary to gain the full advantages of this hot-stamping technology, a les- son learned during Batz’s adoption of the new equipment.
“Operating mechanical presses ver- sus hydraulic presses presents some differences,” he says, “so it was neces- sary to train personnel in understand- ing the data-introduction system for the servo-mechanical press. Once proper training was achieved, we real- ized that the system attains the same force control and even greater flexibility than we had been accustomed to when using hydraulic presses.” MF
The best tooling is American made!
You may not think there’s much difference in tooling for stamping and roll forming, but with our precision punches and buttons, you’ll also get our commitment to provide you the best tooling, at the right time, for the right price. We’ll work hard to help make your operation more efficient and more profitable. Isn’t it time to choose a tooling supplier that really is different?
Because there really is a difference!
www.AmericanPunchCo.com
800.243.1492 info@AmericanPunchCo.com
MetalForming/April 2018 31
