Page 16 - MetalForming-May-2018-issue
P. 16
Motion-Controller Add-On Expands I/O Options
trollers, the RMC200 can direct as many as 32 axes. The CV8 add-on module allows for configurations that handle more axes while consuming less panel space. And, its integration capability can free slots on the backplane for additional function- ality, such as data acquisition.
as well as eight dis-
crete input/output
connections for gen-
eral-purpose control
or data-acquisition
functions. The CV8 out- putsare±10Vat5mA,
and can be user-con-
figured to custom
ranges, such as 0-5 V,
±5 V and 0-10 V,
enabling direct con-
nection to an array of
hydraulic valves. The
eight discrete I/O
points can be individu-
ally configured as either general-purpose inputs or outputs, fault inputs, or enable outputs. These settings can be changed via the same Delta RMCTools software used for the entire Delta RMC-motion- controller family.
Delta Computer Systems, Inc.: www.deltamotion.com
Wear Plate Offers Long Service Life
Delta Computer Systems, Inc. has intro- duced its new, high-density, 8-channel CV8 voltage-output module (CV8) for use with the company’s RMC200 closed-loop electro-hydraulic motion controller. The most advanced of Delta’s motion con-
The CV8 module features eight voltage outputs suitable for controlling an actuator,
OMAX abrasive waterjets can cut a wide range of ma
to
oa
a
d
d
v
va
an
n
c
c
e
ed
dt
te
ec
c
h
hn
n
o
ol
l
o
o
g
gy
ya
a
n
nd
d
a
ac
cc
c
e
e essories.
e
Duroxite 300 overlay plate has been developed by Hardox Wearparts, a division of SSAB, and is designed to provide long service life in wet and dry sliding-wear environments. Compared to traditional tungsten carbide overlay, Duroxite 300 economically delivers high resistance to abrasive wear, according to company offi- cials. The overlay materials contains a high volume of an ultra-fine complex boro- carbide phase. Grain size is refined to 500 nm, reportedly making the borocar- bides approximately 200 times finer than traditional chromium carbides. Reported results include outstanding wear perform- ance and increased impact resistance.
t
t
e
r
r
i
i
a
a
l
l
s
s
a
a
n
n
d
dd
do
o
m
m
o
o
r
r
e
e
t
t
h
ha
a
n
n
k
k
s
st
Get the whole story at omax.com/versatility
The high wear resistance of the boro- carbides allows for a reduced overlay thickness and lighter weight as compared to traditional overlays, and Duroxite 300 maintains a consistent wear resistance from the surface down to 75 percent of the overlay.
14
MetalForming/May 2018
Hardox Wearparts: www.duroxite.com
