Page 14 - MetalForming-Jun-2018-issue
        P. 14
Linear Pneumatic Table Slides
for Machine Tending, Part Transfer
result, allows for optimized blank shape and nesting.
Destaco, Auburn Hills, MI, has expanded its gripping offerings for machine OEMs with the introduction of T110 linear pneumatic table slides, which complement the company’s G110 grippers. Together, they are ideal for high-speed machine part-
Line installation is expected to begin this summer, with the operational handoff scheduled for spring 2019. The line then will join four other Schuler three-laser blanking lines operating in Europe. Schuler Inc.: www.schulergroup.com
adjusters, shocks and stops necessary for installation.
Destaco: destaco.com
Laser-Blanking Line
Headed for Chicago Auto Supplier
The wire former offers a wire range of 0.016 to 0.080 in., and its AT attachment front arm allows a wider range of finished forms and double torsion springs to be made start-to-finish on one machine. Machine features also include simple
transfer, pick-and-place and machine-tending appli- cations, according to company officials.
 The T110 table slides have an indus- try-standard footprint, allowing for drop-in replacement of competing prod- ucts. Other fea- tures include 44 model con- figurations for machine-tending applications; stroke options ranging from 10 to 150 mm; smooth operation via a cross-rollerbearing system; and shock absorbers or rubber stops for fine end-of-
Sixteen-Axis
Wire Former
stroke adjustment.
For slide integration into machines, bundled startup kits include sensors, stroke
RK Trading USA, a supplier of spring formers, coilers, reels and grinders, has debuted the CSX-20-series wire former with AT attachment arm. The 16-axis servo machine features a 3D rotating tooling attachment in front of the wire line, removable optional attachments, and a portable bolt-on forming station, in addition to standard CSX-series features. Users can manufacture parts in small or large quantities, and even prototypes, using the same machine, with the same programming.
Automotive supplier SET Enterprises has ordered a 12-kW three-laser-head Schuler blanking line for its Chicago, IL, production facility. This represents the debut of this particular high-output technology in North America, according to Schuler officials.
SET Enterprises, headquartered in Sterling Heights, MI, supplies blanks and slit multiples to automotive OEMs, Tier-One stampers and sheet mills. The company will use the laser-blanking line to produce blanks for exposed and unexposed automotive stampings. SET Enterprises reportedly chose the Schuler line for its high-output capability and flexibility made possible through Schuler’s DynamicFlow technology. This technology offers three laser heads with the ability to simultaneously cut blank shapes of all types with straight-line cutting speeds exceeding 100 m/min. The blanks are cut from a coil-fed, continuously forward-moving strip of coiled metal, itself traveling at speeds to 60 m/min. This high-output feeding and cutting capability makes conventional blanking dies unnecessary, according to Schuler officials, and, as a
with Attachment Arm
  12 MetalForming/June 2018
setup as well as versatility via eight servo- driven slides, full wire-rotation capability, rotary quill and the ability to add optional single- and dual-axis servo spinners. Anoth- er feature: the EA second-hook finishing station.
RK Trading USA: www.rktradingusa.com
