Page 24 - MetalForming-Oct-2018-issue
P. 24
Better
Fluid Application Means a Better Bottom Line.
See us in booth A1733
I Accurate,consistentlubricantandwatermixing
I Preciseapplicationoflubricanttotoolingorstock I Purificationandrecyclingoflubricant
“I recently worked with our sales team on a proposed stamped part for an OEM customer,” Newberg recalls. “Given this potential customer’s part design, we could not produce it at a reasonable price—feasibility was failing due to splitting issues. We worked back and forth with the OEM’s engineer on part concessions, ultimately reaching a design agreeable to both of us. We did all of this within the AutoForm software modules, receiving a lot of information prior to even quoting part production.
“Once we earned the opportunity to quote production on that part,” he continues, “we already had a good idea of the challenges we would face. Ultimately, due to information gained from the software, we decided on a preform, then trim, then final form to produce the part. Without the soft- ware, our gut feel was to crash-form the part, meaning splitting issues and a lot of tooling recuts. The software helped us upfront to develop our process, using the trim- line-optimization capability to develop the trims. We took the project to a tryout press, made a couple of minor trim adjustments and then qualified the part. We cut steel for production after only two tryouts, whereas in the past we would have performed as many as 10 press tryouts just to dial everything in.”
Leads to Improved Customer Relationships, More Work
See where this is going? The benefits extend well past optimization on a particular part.
“The goal for BTD with this software is to reduce recuts and redesigns, and, as a result, tryout time,” Newberg says, with the example above illustrating success in reaching that goal. “That opens up our equipment and allows us to keep moving forward with original builds without having to back- track for tool recuts and more tryouts.”
Key to all of it, according to Newberg: spot-on correlation between simulation and real-world results.
“If we see a certain percentage of thinning in the simu- lation and I check the parts off of the production floor, the simulation and the measurement are identical,” he says. “When we first used the software, given our experience, we went with our gut feel, hesitant to accept what the software showed. But as years go by and we compare the real world to simulation, we see the correlation.”
Newberg finds that customers are more willing to redesign parts or make other concessions up front during design prior to any tool building. The ability to provide an increased level of part-forming knowledge at that stage can pay off later on when customers are looking for a part producer. And, the software assists this effort in another way through its reporting capability, according to Newberg.
“I can present the data in an easy-to-understand manner,” he says. “Customers do not need to know the stamping world or all of the process details. We can just show the results of simulation and they get it.” MF
Tooling Tryout
PRO-MIX TM plant-wide fluid mixing and distribution systems
For over 35 years, we have been providing line-side and plant-wide lubrication solutions. We know how to save you money and create a cleaner, safer workspace.
Call us today to learn more. +1 (616) 249-1525
IndustrialInnovations.com
Boost productivity. Reduce fluid use. Save money.
22
MetalForming/October 2018
