Page 77 - MetalForming-Oct-2018-issue
P. 77
Next-Generation Laser Technology
features a helical rack-and-pinion positioning system that delivers high cutting speeds for maximum throughput. Mazak’s Intelligent Functions with the Multi-Control Torch help to increase the end- user productivity by allowing the machine to optimize setup automatically for each program. The company also will show other laser-cutting machines and an automation system.
www.mazakoptonics.com
Hydraulic Presses and Related Automation
ROSS CONTROLS
SAFETY EXHAUST DOUBLE VALVES CATEGORY 4
for Control of Clutch/Brake Mechanisms Control Reliability
Self-Monitored
DM2® D
Dynamic Monitoring & Memory
SERPAR® E-P Monitor
AUTOMATIC COUNTERBALANCE SYSTEMS
Flexible Assemblies with Built-in Manual and Automatic Circuits
(High Pressure Options now Available)
AIR DISTRIBUTION PRODUCTS
Modular Designs Assemblies
CYLINDER CONTROL VALVES CAT-4
® 5/2 CROSSMIRROR
for Die-Clamping
ENERGY ISOLATION
VALVES
Manual L-O-X® for Lockout/Tagout
Visit ROSS Booth #A1759 at FABTECH 2018 November 6-8, Atlanta, GA
GLOBAL Reach with a LOCAL Touchsm
1-800-GET-ROSS www.rosscontrols.com
Mazak Optonics Corp. Booth B7529
Mazak Optonics will launch its Optiplex 3015 DDL 6-kW direct-diode laser-cutting machine. Utilizing flying optics, two- pallet-changer design and a digital-drive package, the machine
Greenerd Press & Machine Co. Booth A1245
Greenerd Press & Machine Co. will showcase its hydraulic- press and automation capabilities, while the company’s application experts and design engineers will be available to discuss spe- cific user applications and
press requirements. Unique applications include a Greenerd- designed and -built transfer line for an automotive com- pany. The line (pictured) includes three stations that draw, redraw and punch a component, and features 250-ton draw presses and a 150-ton punch press.
Line speeds exceed 2000 in./min.
The company’s extensive hydraulic line range from gap-frame
and straightside to die-spotting and forging presses, with unlimited size and tonnage capabilities.
Also, Greenerd is a Fanuc Tier-One industrial authorized robot-system integrator. The partnership gives Greenerd full access to the comprehensive offerings of Fanuc robots, including all models, training and support, and allows for development of state-of-the-art automation solutions in short timeframes.
www.greenerd.com
MetalForming/October 2018 75
