Page 11 - MetalForming-Dec-2018-issue
P. 11
  The smallest models in this same line, a CSP 100 single-rod automatic blanking press and a MSP 200 double-rod automatic blanking press, already have found use with metalformers, according to Schuler officials.
Like all of the line’s models, these presses employ innovative knuckle-joint drives with dynamic servo motors and additional smart functions, such as con- dition monitoring.
Schuler plans soon to add a 1250- ton model to the line.
Schuler: www.schulergroup.com/ servopresses
Newly Designed Dust Collector
The new Gold Series X-Flo (GSX) indus- trial dust collector from Camfil APC is ideal for industrial applications that pro- duce or process fine, fibrous and heavy dusts and fumes. Designed in modules, GSX collectors are simple to assemble. Each module handles airflows to 6000 cfm using four Gold ConeTM X-Flo filter cartridges.
Camfil designed the new filter cartridges with added pleated media and surface
area, enabling them to move more air and process more dust without increasing the collector’s overall footprint.
The collector also features a newly engineered inlet and unique baffle con- figuration that creates a more uniform airflow, which extends filter life. When the filters are pulse cleaned, more dust is channeled directly into the hopper
instead of into the adjacent filters.
GSX dust collectors exceed OSHA man- dates for indoor air quality and are tested to meet NFPA and ATEX standards. They are available with explosion protection options including explosion vents, isolation valves, integrated safety-monitoring filters
and fire-retardant filter cartridges.
Camfil APC: www.camfilapc.com
        The best tooling is American made!
You may not think there’s much difference in tooling for stamping and roll forming, but with our precision punches and buttons, you’ll also get our commitment to provide you the best tooling, at the right time, for the right price. We’ll work hard to help make your operation more efficient and more profitable. Isn’t it time to choose a tooling supplier that really is different?
Because there really is a difference!
www.AmericanPunchCo.com
800.243.1492 info@AmericanPunchCo.com
MetalForming/December 2018 9
   9   10   11   12   13
