Page 32 - MetalForming-Dec-2018-issue
P. 32
  Fabrication: Bending
Speed Drives Innovation
“The RAS equipment is super-fast and super-efficient,” continues Dunn. That’s the good news, but it brought a challenge. Conventional means for offloading the large formed parts couldn’t keep pace with the RAS equip- ment. While MRI bought the RAS with dual-gantry auto-load technology, capable of loading two 36-in. stacks, or 600 sheets, the company’s parts are so large that the system had to stop every couple of minutes for offloading.
That didn’t last long, says Dunn, as MRI soon added a six-axis robotic unloader and skeletized the parts— bending four parts on a skeleton. A fiber laser perforates those parts so that once bent, the operators, and now the robot, snap out the bended parts, with the robotic unloader providing for fast offload.
“With the skeletized parts and the RAS bender and robotic unloader, we’re producing and unloading parts faster than ever,” says Dunn. “Our system
Whether outfitted with roller or brush tables, the bending system creates precise bends without sacrificing surface quality due its folding style. Rather than wiping against material, adjustments are made for the necessary material radius on multiple axes as the folding beam actuates.
 can run from 10 min. to a couple of hours before operators need to step in to remove the full pallets.”
MRI’s bending improvements have resulted in labor savings, increased capacity and accuracy. Moreover, says
Dunn, “because the corner fitup is the best our welders have seen, weld time is down and quality is up, while in product assembly everything fits, elim- inating the need for filing, drilling or forcing parts together.” MF
                                            With support by:
                  February 12-13, 2019 • Schaumburg, IL
This conference will bring stampers and die shops up to date on new lubricants for stamping and tool and die machining, and help them evaluate new formulations and select the right lubricant for the job. Attendees also will come away with an understanding of the various techniques available for applying lubricant, to ensure optimum application while minimizing waste.
Topics include:
• Selecting the right lubricant for the job, based on material type, thickness, etc. • How to evaluate lubricants
• New trends in lubricant formulations
• Lubrication-system selection
• Automotive OEM requirements
• Regulations surrounding lubrication
Our sponsors:
More information at metalformingmagazine.com/lubetech
                                                30 MetalForming/December 2018
   30   31   32   33   34
