Page 26 - MetalForming March 2019
        P. 26
                     Press Controls
   increases the efficiency of complex forming operations and reduces sec- ondary operations. Unlike servo-driven mechanical presses, according to com- pany officials, a servohydraulic press with I-Press can deliver as much as 100 percent of press tonnage at any point in the stroke, with users given the abil- ity to program dwell time at the bottom of the stroke prior to decompression and upstroke return to TDC.
The I-Press multipoint job-setup screen features a slider-bar function— users can drag it to a setpoint, or tap to enter numeric values for all approach,
dwell and return motions. With the I- Press AB Hydro control, along with servo-driven pumps and the multipoint edit screen, users can optimize motion, pressure and position curves to opti- mize part output and die life. Remotely monitor and troubleshoot by connect- ing the control to mobile devices. Sutherland Presses: www.sutherlandpresses.com
Easily Installed Ergonomic Touch Buttons
For use wherever ergonomic touch buttons would be deployed, or to replace mechanical buttons, Cieco offers its Saf-T-Touch ergonomic safety touch buttons. The buttons, opera- tional with gloved hands, reduce the chances of carpel tunnel syndrome and fatigue in repetitive operations via ergonomic no-force actuation. Diverse dual-sensing technology prevents inad- vertent actuation from false triggering sources, and redundant processors with dual monitored outputs provide
control-reliable operation. For trou- ble-free performance, the buttons fea- ture electromagnetic compatibility, meaning superior noise immunity from external radiated and conducted noise, according to company officials.
Installation is simple, with indus- try-standard 30.5-mm-hole mounting and pluggable terminals to simplify wiring. Indicators provide for simple troubleshooting and output status, and solid-state terminals eliminate the need to replace buttons due to worn relays. Cieco Inc.: www.ciecocontrols.com
Enhanced Servomechanical Press Operation
The combination of Stamtec’s ser- vomechanical-press offerings and con- trols enables virtually an unlimited number of stroke and slide-movement profiles, while supplying full working energy even at slow speeds/dwells. Controls specifically designed for ser- vomechanical presses feature user- friendly interfaces, and given the stroke and slide-movement flexibility, enable users to perform a variety of jobs— drawing, restrike, warm forming, etc.— in one press. Stamtec can custom-sup- ply unique profiles, while customized motion curves allow as many as 20 var- ious segments in a cycle curve, defined by segment position, speed and pause- duration parameters.
The controls can incorporate automation and feed applications, and enable automatic slide adjustment and die-height auto-correction. Other fea- tures include 100-job storage, pulse generator wheel for die try-out, Eth- ernet link and incorporation of task- assignment software.
Stamtec: www.stamtec.com MF www.metalformingmagazine.com
   Press Controls For All Presses
 One Source
One Solution
Toledo Integrated Systems
  Press Pilot 150 Control
We Provide Solutions For...
Mechanical Presses Hydraulic Presses Forging Presses Transfer Presses
Maximizer TPC (Total Press Control)
Toledo Transducers, Inc.
www.ToledoIntegratedSystems.com 800-T-Toledo 419-867-4170
 24 MetalForming/March 2019
