Page 27 - MetalForming August 2019
P. 27
FABRICATION
Laser Job Shop
the Perfect Stamper/Spinner Partner
A new five-axis laser- cutting machine, along with new processing and control software, improves productivity at this job shop serving numerous metal spinning and stamping companies.
There’s flat laser cutting and then there’s complex 3D cutting using a five-axis laser system. No one knows both processes better than Lasercraft USA Inc., North Ridgeville, OH, a laser cutting job shop that spe- cializes in producing formed metal parts (including stamped and spun metal parts) with laser cut features.
Lasercraft processes cold-rolled steel, aluminum and stainless steel, from the thinnest sheet that ranges from 0.060 to 0.120 in. to the thickest —11 to 16 gauge. Tube diameter maxes out at 14 in.
Most of Lasercraft’s projects call for laser cutting of custom-designed formed parts with complex geometries —work that many metal spinners and stampers often prefer to subcontract. Serving that market for more than 20 years, the firm operates more than a
As explained by Lasercraft president Gregory Claycomb, the firm’s latest addition to its laser-cutting machine stable provides ideal for cutting features such as slots, complex hole patterns and precision shaped edges in contoured stamped and spun parts
MetalForming/August 2019 25
dozen laser-cutting machines, the newest of which is a five-axis Prima Power Laserdyne 430 workstation. This new addition to the Lasercraft shop offers a large work volume (585 by 408 by 508 mm) and is designed for metal and nonmetal cutting, welding and drilling. It boasts the Prima Power BeamDirector compact rotary- and tilt-
axis head—900 deg. of rotary motion and 300 deg. of tilt motion—reportedly the only head that allows drilling at an angle of 10 deg. off of the surface along the entire stroke of the linear axes.
New Software Enhances Machine Performance
