Page 22 - MetalForming October 2019
P. 22
QDC as Soft Automation
Quick die change (QDC), the safe, efficient and
rapid movement of dies, need not be complicated,
but must be present. Mark Scanlan, vice president and general manager of Germantown, WI-based PFA, Inc., shares his QDC views with MetalForming.
The three basic components of a quick die change application: clamps (blue), die lifters (red) and bolster extensions (yellow).
opportunity for improvement and sav- ings at many levels.
MetalForming: Please describe ways to make SMED less costly and help improve return on investment (ROI).
Scanlan: Like all processes, any opportunity for multiplicity and redun- dancy improves efficiency in both pro- duction and equipment utilization. Multiple matching presses provide opportunities. For example, lower-cost attachment points can be mounted to multiple presses and a single set of lift- off bolster extensions used to service all of them. Spreading the cost of the more expensive components across multiple systems requires good plan- ning and helps to improve ROI. Another example: manual die lifters moved among standardized presses. Many customers prefer to install always-avail- able dedicated equipment. Each case differs, which is why it is important to work with an experienced company that will help explore all the options.
MetalForming: Any final thoughts on QDC?
Scanlan: No longer a nice-to-have option, QDC should be part of standard equipment for all presses. The systems are well defined and easy to implement, especially on small presses that histori- cally have not been fully optimized. Safety is so important. If you do not have QDC in place, now is the time to act. MF
MetalForming: What is one of the biggest challenges facing die stamping customers today?
Scanlan: Trained and experienced staff are hard to find in the current economy. New customers say that the aging talent pool reduces the ability to push dies around even in smaller press- es, raising concerns over injuries. Meanwhile, retirements limit senior- staff availability to support complex die changes. Additionally, personnel are not available to perform slower manual die changes or multiple die changes at facilities that have been slow to adopt QDC systems.
MetalForming: How can QDC prac- tices help?
Scanlan: QDC can be thought of as another way to soft-automate produc- tion, and really should be considered as one part of improving efficiency and quality in the overall production system, while also reducing risk of injury and downtime. I call this soft automation because human experience and talent is retained in the process to maintain flexibility and responsiveness. Not all automation involves robotics or software. Automation can be anything that improves the process, removes complex manual behaviors, and replaces those actions with automatic improvements. Thinking about QDC as an automation process provides a different perspective.
MetalForming: What does QDC as soft automation look like?
Scanlan: It has to do with finding ways to maximize the talents of staff using QDC hardware, such as hydraulic clamps, die lifters, bolster extensions and related equipment designed to optimize die movement and placement. Employing QDC not only results in the desired single-minute exchange of die (SMED); more importantly, it maxi- mizes the efficiency of staff while reduc- ing management burden and risk. QDC practices must become so common that their absence in a manufacturing environment would be unimaginable. No one considers lifting pallets by hand; instead, we use forklifts without really thinking about them. The same needs to happen when it comes to QDC.
MetalForming: It sounds like you recommend QDC for all applications. Is that the case?
Scanlan: Certainly, some method of safely moving dies to minimize risk is necessary. On the other hand, in cases where a single die stays in the press for months, die loading can be performed safely, but slowly, and with less investment than highly efficient QDC systems. Seldom-moved dies don’t require SMED. In most produc- tion environments, however, dies move frequently with hours spent changing a single die. This provides a great
20 MetalForming/October 2019
