Page 48 - MetalForming October 2019
P. 48
Conference Sessions
pin connectors, properly seated blanks and gripping of parts can cause dam- age to the transfer, the die set or press. Integrating sensors in the die, gripping of parts and improvements in connec- tivity will be discussed through real- world case studies.
Will Healy III, Balluff
Is ERP an Effective Solution for Die Makers
and Metal Fabricators?
Die manufacturers looking to select and implement a new ERP system in their shops have a critical decision to make. Do you go with a large generic ERP solution that provides the “one size fits all” type functionality? Or, do you consider a more industry-specific ERP solution that provides the func- tionality that meets your set of stan- dards? Learn about the “right” software to increase your bottom line and what to look for when considering imple- menting an ERP system.
Jeanne Naysmith, TST Software
10–11:30 a.m.
Materials 2—The Effects of Automotive Lightweight Initiatives on Die Design Strategy and Construction
Today’s automotive lightweight ini- tiatives include the increased use of aluminum, stainless steel and advanced high-strength steels (AHSS) in automo- tive chassis, body structure and interior systems. This presentation examines important mechanical and physical properties for each material type, their effects on the metal-stamping process and, in turn, their impact on die design and construction practices.
Peter Ulintz, Precision Metalforming Association (PMA), and
Danny Schaeffler,
Engineering Quality Solutions
Connectivity 2—Case Studies of IO-Link Modernizing
the Press Shop
Tired of broken cables, incorrect
press setup, misfeed and downtime due to equipment failure? Press shops are being revolutionized by the open standard, IO-Link (IEC 61131-9). Real world case studies show how IO-Link works to eliminate downtime in the press shop from shut height, roll align- ment and quick die changes, and improves press maintenance.
Will Healy III, Balluff, Inc.
I-PRESS, the Future of Press Control Technology
Highly advanced and easy-to-under- stand software-based press controls systems that allow for greater automa- tion integration and productivity will be discussed. This presentation also addresses control systems for mechan- ical stamping, servo-hydraulic and hot, warm and cold forge presses.
Ray Fausz, Sutherland Press
2–3:30 p.m.
Materials 3—Focus on Materials:
46 MetalForming/October 2019
