Page 67 - MetalForming October 2019
P. 67
offerings are ideal for clamping dies with a straight
clamping edge. Since the clamp operates by spring
force, no permanent hydraulic supply is necessary, and
only 160-bar pressure is necessary for release. The
self-locking clamping bolts are monitored by inductive
switches and visual position monitoring. Compact and
robust, the wedge clamps can withstand temperatures
to 160 deg. C, and come with a rust-protective coating. Highly
adaptable to numerous applications, the wedge clamps offer maximum flexibility when used with hydraulic connections, even in the standard range of cylinder diameters
from 35 to 85 mm.
www.hilma-usa.com
Benchtop Presses
Multipress Booth D45054
Multipress displays its model M5P benchtop press with dual anti-tiedown start buttons, pressure-shift speed change and pressure reversal, and the ability to run with an optional rotary index table. All adjustments, pressures and stroke positions can be modified from the oper- ator’s position at the front of the press, and pressure regeneration allows for fast approach until work is contacted.
Several standard models are available with capacities ranging from 6 to 20 tons. Company representatives discuss addi- tional customized press solutions, as well as the full line of standard Multipress
The Learning Curve Redefined
dmiral Steel craftsmen have not only mastered the Learning Curve, they’ve slit, sheared, reflattened, deburred, blanked, edge-conditioned, and cut it to length.
With an average tenure of 17 years per employee we have unrivaled experience to turn our extensive inventory into the stock you need – when you need it.
Booth D46251
4152 West 123rd Street Alsip, Illinois 60803-1869 Ph: 800-323-7055 Fax: 708-388-3412 sales@admiralsteel.com Se Habla Español
For over 70 years A
presses.
www.multipress.com
ANNIVERS
Admiral is a registered trademark of Admiral Steel LLC. Alsip, Illinois. Reg. No. 2430959. All rights reserved.
SARY
Self-Locking Wedge
Clamps for Dies
Hilma Division of Carr Lane Roemheld Booth D45857
Representatives from the Hilma Division of Carr Lane Roemheld are on hand to discuss the company’s self-locking wedge clamps. Powered by spring force, the new
dmiralste ISO 9001 REG
A
Ad
TM
TM
MetalForming/October 2019 65
el.com ISTERED
