Page 74 - MetalForming October 2019
P. 74
10-kW Fiber Laser Cutting Machine
Prima Power North America Booth A2941
Prima Power North America shows the Laser Genius fiber laser cutting machine with a 10-kW laser, which promises high cut quality on thicker materials. This machine benefits from improved integration of all machine components, and the innovative use of materials such as the carbon-fiber carriage and synthetic-granite frame, according to company officials. The high-dynamic linear motor reportedly helps increase productivity by as much as 20 percent as compared to conventional transmission systems.
Effective CNC management of the linear drive results in accurate and repeatable cutting and positioning of the laser head. The technological core of Laser Genius, the laser head, features adaptive optics for automatic management of focal position and diameter and for rapid, reactive and accurate stand-off measurement.
To best meet various production needs, the machine can be integrated with various suites of options: Smart Cut, which allows a cycle-time reduction of as much as 30 percent during high-pressure cutting or on material thicknesses to 6 mm; Max Cut, which enables cycle-time reduction to 40 percent for oxy- gen-assisted processes and for materials from 6 to 25 mm thick; Night Cut, for complete control during unattended operations; and Control Cut, which allows the process to automatically adapt
to the machine con-
figuration and the status of the devices.
The Laser Genius can be equipped with a range of automation modules for loading, unloading, storage, sorting
and stacking.
Fabrication Tools
Wilson Tool Booth A3114
www.primapower.com
The Impax Tooling Solutions
division of Wilson Tool Interna-
tional shows everything from
standard punches and dies to
custom tooling and punch retainers. HP Accu-
Lock inserts enable customers to make and modify retainers on-site and on demand. Engineers on hand can discuss tooling solutions for even the toughest of applications.
www.wilsontool.com
All you need for tools
Your partner for punching and bending technology
Wether guide units, system springs or nitro- gen systems: with its extensive product range STEINEL provides everthing you need for com- plex punching tasks.
Visit us at FABTECH in Chicago and get to know selected highlights like our guide bushes with adhesive grooves and our miniaturised high-speed manifold plates.
www.steinel.com
72 MetalForming/October 2019
FABTECH CHICAGO
11– 14 November . Hall D . Booth D45266
