Page 79 - MetalForming October 2019
P. 79
Tools for Tapping
Jarvis Cutting Tools Booth D45029
Representatives of Jarvis Cutting Tools are on hand to discuss why Jarvis taps are used extensively; 75 percent of all oil-filter plates are tapped with a Jarvis tool, according to company officials.
Working directly with machine builders to design exclusive high-performance taps, the company has developed a number of technologies that address current and future production requirements. One exam- ple: tooling specifically for an advanced high-strength steel application is at the booth. www.jarviscuttingtools.com
Saws, Ironworkers, Pipe Notcher/Grinder
Scotchman Industries Booths A3532, A3732
Scotchman Industries provides live demonstrations of its new CPO 350 AutoLoader (pictured), a fully automatic sawing system designed to save time, reduce scrap and eliminate mistakes. Scotchman has taken the semi-automatic CPO 350 PKPD saw and added an auto- loading system, creating new system that cuts multiple lengths of tube in diameters to 3 in.
The saw comes standard with a Win- dows-based touchscreen control, 5-hp variable-speed motor, 315-mm-dia. blade and the ability to run unlimited cut lists in lengths from 0.5 to 23 in. Run a com- plete cut list or run of cut lists at 90 deg. on an automatic cycle, or switch to operate the saw in a semi-automatic cycle to miter cut. Rapid setup, automatic part-length change and fast reloading of material adds efficiency.
Scotchman also showcases its 50- ton ironworkers: models 50514-EC and 5014-ET. Couple the equipment with the RazorGage digital length-positioning sys- tem, where the RG Digital Quick-Stop accurately positions material to the exact length in the ironworker. Using 50 tons of hydraulic pressure, the ironworkers can punch a 1.25-in.-dia. hole in 0.5- in.-thick plate and a 13⁄16-in.-dia. hole in a 0.75-in.-thick plate. The 50514-EC has
a single punch station and the 5014-ET offers a three- station revolving turret punch station.
And, the company introduces its AL150
HS high-speed abrasive grinder/notcher, which
includes a grinding belt and pipe grinder. This new
machine creates notches in seconds and is 40-percent faster than the original AL150, according to Scotchman officials.
www.scotchman.com
HYDRAULIC PRESSES
For o
& Machine Company
ver 135 year
rs,
Greenerd Press
d and back the best hydraulic solution for your needs.
Newly Redesigned/ Expanded Greenerd
Manufacturing Fa
acility
We
e will design, build
800-877-9110
MetalForming/October 2019 77
