Page 25 - MetalForming January 2020
        P. 25
                                                 Looking for Fine Plasma or Laser?
 Fine Plasma 5-Axis Laser
        MORE POWER
MORE FLEXIBILITY MORE OUTPUT
                  The new Komatsu TFP does all this and more.
300 Amps of Fine Plasma Power to cut 40mm (1.6˝) mild steel at 45 IPM and the finesse for 1.6mm (16ga.) at 200 IPM. PLUS switch to Oxy cutting 2˝ thick plate in less than 30 seconds by a simple nozzle change. And with only 1-cutting head there is no “dead zone” on the table so you can nest plates using the full table size.
 Standard Features of Twister:
• Automatic Gas Change Option
• Automatic Parameter Settings
• “Push-Pull” zoned exhaust system
• 2 year warranty on all components
• Laser positioner included
• Automatic anti-spatter system
• Argon Marking system
• Single Cartridge consumable technology
NEW “Single Cartridge” only at KOMATSU
            T
x
T
T
L
L
L
L
L
L
M
M
MS
S
Se
e
e
e
e
e
r
r
ri
i
i
i
i
e
e
e
e
e
s
s
so
o
o
f
f
f
f5
5
5
5
a
-a
x
x
ax
i
i
i
i
i
s
s
s
s
     Mon. 3
Titanium (0.030 in.)
Tues./Wed. Mild Steel
(0.050 in.) w
Thurs. Galvanneal
e
en
n
ns
s
s
si
i
i
i
io
o
o
o
o
na
a
a
l la
a
as
s
e
           3-
d
d
di
im
me
s
e
er
r s
s
sy
y
y
y
ys
s
s
s
s
s
t
t
t
t
t
t
e
e
e
e
e
m
m
m
m
s
s
s
s
s
                                             i
i
id
d
d
d
e
e
e
a
a
a
l
lf
f
fo
o
o
o
or
r
r
rc
c
cu
u
u
ut
t
t
t
t
t
t
t
t
i
i
i
i
in
ng
gc
co
o
o
om
m
ple
e
e
e
x
x
                                                     c
x
co
o
o
o
n
nt
t
t
t
o
o
o
o
ou
u
ur
r
r
r
r
r
s
s
sa
n
n
n
d
d
d
d
s
s
sh
h
ha
a
p
p
p
p
e
e
e
e
e
s
s
s
s
                  T
T
TL
L
L
LV
VS
S
Se
e
er
r
r
i
i
i
i
i
e
e
e
e
e
s
s
s3
3
3-
d
a
a
ax
x
x
i
i
is
s
sh
hy
y
yb
br
r
ri
i
i
i
i
d
d
                              ma
a
ac
c
h
h
in
n
e
e
e
es
s
s f
fo
o
r
r la
a
a
r
r
r
g
g
g
      w
s
d
e
e
an
nd
d
                                          i
i
i
i
id
d
d
e
ew
w
w
o
o
o
o
or
r
r
r
k
k
k
k
k
p
p
p
p
ie
e
c
c
e
e
s
s
                                            T
TL
L
L
LX
S
S
Se
e
e
r
r
r
r
ri
i
ie
e
e
e
e
s
s
s hi
i
ig
g
g
g
e
e
e
e
h
h
h
p
r
r
r
5
p
p
5
a
o
ow
a
a
w
w
w
w
ax
i
i
i
i
i
e
e
e
e
e
s
s
s
s
r
r
r
                                 3
3-
-a
a
a
x
x
x
x
xi
i
i
i
i
i
s
s
s in
n ca
an
n
n
t
t
t
t
t
i
i
i
i
l
l
le
e
e
v
v
v
e
e
e
e
r
r
r
an
n
n
n
d
d
d
d
 (0.039 in.) ga
     a
n
nt
t
t
t
t
r
r
r
r
r
y
y
y
c
c
c
co
o
o
on
n
n
n
fi
fi
fi
fi
fi
g
g
g
u
u
r
r
a
a
a
a
t
t
t
t
i
i
i
i
o
o
o
on
n
s
s
s
            T
x
T
L
L
L
L
L
H
HF
F
i
i
i
ib
b
b
b
b
b
e
e
e
e
r
rL
La
a
a
as
s
s
s
s
e
x
x
s
     Fri./Sat.
Aluminized Steel s
(0.046 in.)
            3
l la
r cu
3
d
di
i
m
m
e
e
e
e
n
n
ns
s
i
i
o
o
na
a
l
a
s
s
e
e
e
e
r
u
u
ut
t
t
t
t
t
t
t
t
i
ng
i
in
                                                 s
s
y
y
y
y
y
s
s
s
t
t
t
t
t
e
e
e
m
m
s
sf
fo
o
o
or ul
l
l
l
t
t
t
t
t
r
r
r
r
r
a
a
a hig
g
g
h
h sp
p
e
e
e
e
e
e
e
e
d
d
        an
d
n
n
n
d
d
d
d
ve
e
e
r
r
r
r
r
s
s
sa
a
a
a
t
t
t
t
t
i
i
i
l
l
l
li
i
i
i
i
t
t
t
t
t
y
y
y
y.
                 IF THIS IS A TYPICAL WEEK AT YOUR SHOP... WE SHOULD TALK.
When you’re 5-axis laser cutting, it’s all about flexibility and speed.
The flexibility to cut thick plate one day; exotic alloys the next and parts with intricate shapes the next. Our laser systems are in a word, flexible. Flexible to adapt to your ever-changing processing needs. Flexible to perform the simplest to most demanding cutting jobs.
Our 5-axis laser cutting systems also give you speed. With rapid feed rates to 1,575 in/min and cutting feed rate to 1,181 in/min and accuracies of ± 0.0012 in. per 12 inches of travel, Komatsu Laser sets the standard for 5-axis laser cutting.
So whether you’re cutting titanium on Monday, mild steel on Tuesday or galvanneal or Wednesday, think of Komatsu Laser as your laser cutting resource.
 Komatsu is your single source for all your cutting needs
